Cars & Trucks Logo
Lorraine Davis Posted on Jan 08, 2012
How do you bypass the security system in a 1999 Nissan Maxima?
I want to totally disconnect th security system in my 1999 nissan maxima without having any other issues that my be a result of disconnecting the security system.
karen hendy
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 22, 2013
karen hendy
Contributor
Level 1:
Answers
Questions
0
Helped
3446
Points
0
Im buying a 1999 nissan maxima it did not come with a keyless entry lock remote i never had this kind of a car so i did not know it needed one i noticed the alarm was beeping before i started it but stopped after i guess i did not check the car over good enough before getting it it takes a few times trying to start it before it starts and noticed the key i have to start it does not lock the doors can i by pass the alarm.?
5 Related Answers
Anonymous
  • Posted on Apr 07, 2009
SOURCE: 1999 Nissan Maxima-wont start, no injector pulse
I have a service manual. I suppose you are talking about the anti-theft system. It says that if there is power going to the starter when you try and start that the anti-theft system is ok and that means that it is allow the car to start. If there is not power to the starter then your anti-theft system is stopping the car from starting for some reason.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 23, 2008
SOURCE: Check Engine Light 1996 Nissan Maxima
The best way is to use a scan tool to clear the codes, that will turn off the light, also disconnecting the battery over night may work, but no completely sure about that, it varies from year to year.
hiseyj
Jackson Hisey
  • 99 Answers
  • Posted on Nov 26, 2008
SOURCE: i have a 1999 nissan maxima with code P1320
This code is a crapshoot. There are two main things it could be and they are both expensive. There could be wire breakage in the engine harness. There is a thick harness coming out of engine bulkhead on the passenger/right side and it has a slight bend to it. With the engine idling grab that bend and give it a couple of twists and yanks. If the engine stumbles or misses that is the source of your troubles. If not, you more than likely need to replace the coils. Any one of the six coils could be causing the code so I recommend replacing all six at the same time. You could buy one coil for the front bank and one for the rear and swap it between cylinders to see which coil is causing the code. This is time consuming but cheaper.
Anonymous
  • 379 Answers
  • Posted on Jan 04, 2009
SOURCE: location of a o2 sensor 2001 nissan maxima
bank 1 refers to the side of the engine that #1 cylinder is on , and sensor 2 refers to downstream , after the catalytic converter. , this link shows bank 1 on a 2001 nissan maxima V6 being on the firewall side . if you had a 4 cylinder it would be downstream after the catalytic converter .
http://www.autozone.com/N,26200242/shopping/specsSelect.htm
David Velazquez
  • 4 Answers
  • Posted on Mar 06, 2009
SOURCE: i hooked up a new radio in my 96 nissan maxima and get no sound.
Hook up the Amp Turn on Wire usually blue/white strip
2answers
1996 Nissan Maxima will not start?
I would check the mass air flow sensor. It could have a cobweb or spider web on it. It has to be real clean but when you clean it use carb and choke spray.
1999 Nissan Maxima won't stay running, had it hooked up to a diagnostic tester
That is the security system problem, you need a special scanner to diagnose that system.
2answers
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
Can I bypass Nissan Maxima 2001 security?
Everything I have read online says you cannot bypass the Nissan Anti Theft System.
2answers
How to reset security system on 1999 Nissan
friend of mine had same issue security system didn't let the car start so the only fix was to take the car to the dealership to reprogram the computer
1helpful
Removing radio unit from 1998 Nissan Maxima
FIRSTURN OFF CAR take keys ou look for a rectangular face plate plasti. take off . thfind th e screws take them out and dont lose .. then slowly pull head unit ou . there is a bundlr of wires that goto a connecter that connects to anoyhter bundle. un hook at clear connector i said
2helpful
My 1999 nissan maxima 5 speed won't shift from 1st to second gear.
If it goes into other gears correctly, then the issue is likely a synchromesh problem with that particular gear, and the gearbox may have to be stripped.
You may try changing the gear oil first though, as this can often fix the issue without having to spend too much money on unnecessary repairs.
I had to replace the engine on Nissan Maxima the mechanice is telling me he needs information on resetting/bypassing the factory security system on the vehicle because it wont start
it cant be "bypassed". it needs to be FIXED. Are you using the original key? a dealer or shop familiar with NISSAN may be required to check it out.
1helpful
How do i bypass the security system or disablethe system. for a 95 Nissan maxima
if its stock alarm, you must close all the doors and lock then unlock it using the pwr lock button. If this doesnt work try the same method with the key set to ON...hopefully this helpd!!
2helpful
1999 Nissan Maxima will not start up
for that look up alldata or mitchell on demend
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
