Question about LG Shine KE970 Cellular Phone
How to set BD address
When i try to connect bluetooth lg shine cu 720 ask me to set bd address. how i set it's bd address?
  • aukalani Dec 22, 2008
    I have the same problem with my CU 515. love the phone but can't make it pass this BD address pop up?!
  • Anonymous Feb 22, 2009
    i cant bluetooth any music without setting up my bd address
The same problem with my lg u960 , he ask me for BD address :-s ...HELP !!!
Posted on Oct 21, 2008
I dont´t know if i can help you very much, but when you go to Bluetooth settings and chose My address there should be a code. My says 00:1F:6B:F0:F5:48, every phone should have a individuelle code or "address".
Posted on Oct 10, 2008
Posted on Nov 05, 2008
  • amin_viplav Nov 05, 2008
Hi there , I am trying to watch Planet Earth blue ray disc on lg bd 390 and for some reason any of the discs does not load (there is 6 of them).i thought it was a bad product and I asked for an exchange...
Try disabling BD-Live.
On the LG BD390 go to the Home screen then select the following:
Settings-->Network-->BD-Live Connection
You have three options: Permitted, Partially Permitted (default), and Prohibited.
Change the setting to Prohibited.
Now reload the disk and try again.
If that doesn't work try clearing the BD Storage (memory about the disks you play).
Again from the Home screen:
Settings-->Others-->BD Storage Clear
I think changing the BD-Live setting will stop the problem you're experiencing. If that works, you could also try changing the setting to Permitted.
I am experiencing issues with some of the very latest Blu-Ray disks, such as Avatar and Date Night. I don't have enough experience to be sure yet, but so far the evidence points to a new setting or standard in the disk industry that does not play well with the Partially Permitted default setting on the LG BD390 and a few other Blu-Ray players.
I hope this helps. Good luck.
May 22, 2010 | LG BD390 Blu-Ray Player
LG Shine CU 720
why cant u try paring the phone with some other bule tooth unit?
Jun 11, 2008 | LG Shine KE970 Cellular Phone
When i ture my bluetooth something popup that you must set bd address please help me
The address isn’t something that can be set, that’s a MAC address - it’s the unique identifier for the bluetooth chip on the phone (all network cards have them).
I would hazard a guess that either your bluetooth stack on the phone is goosed or the chipset itself.
OR
Try this:
Turn the Bluetooth Off, disconnect it from the PC, turn it on, re-connect it to the PC.
Go Start -> (All) Programs -> QPST -> QPST Configuration.
Click on the PORTS tab.
Bluetooth Address:
Since you upgraded the phone, you already have the usb drivers.
Now, launch the QPST configurator.
Click on "add new port"
Type the port number your phone is using now. (you put it COM5, COM10, etc, its just one example) -----------------If you already added your port in QPST then skip this.
Now, launch the NV editor, maximize the window.
on connect, select the com port, and press connect server.
press the file button and select upload all from mobile
Then, press the search button, and type "447"
Move the file to the "selected" window.
Once you double click it, in another window you will see loads of firlds with 0
Change the to 1, all of them.
also, change the string value to "true"
Now, you press the "file" button and press "download selected & active to mobile"
Disconnect the server, close the program, unplug the phone, and restart the phone.
Now, try to enable the bluetooth.
Remember, once you do the 6th image step, you go to connection and select disconnect server.
All fixed!
Good Luck & Thanks,
Shiv.
Aug 20, 2009 | LG Shine KE970 Cellular Phone
Lg viewty ku990 bluetooth bd address not setny help would be appreciated, my lg viewty ku990 when trying to turn bluetooth on it comes up with the message you must set the bd address. ive looked in th
I think that the bluethoot of your pc or your LG KU990 (Viewty) Has no name. Your bluethoot address have a IP address but for the windows you need to put nthe name. Give your device a name that windows can find and vise versa. Most bluethoot softawe find the phone but sometimes you have to it in a otherway. Remove the item in the profile list of your bluethoot software that you made it for the phone. Now sometimes you have to turn off and on your phone cause there will be a program still running on the background of your phone. So when you want to find your LG KU990 (Viewty) you have to do it vise versa. Find your Pc or Laptop with your LG KU990 (Viewty) in this way the bluethoot will find the address and ask you for a security code. In this case you can make a password. EXAMPLE 1234 or NicKy what ever you want. Then the bluethoot software will setup the modem drivers of your phone so you make an connection with the bluethoot. Sometimes you have to reinstal the drivers to make the software work correctly. I hope this will help you out. Fallow the steps when the drivers will be ready to install. Best regards; Henk Muskita.
Jun 02, 2009 | LG KU990 Viewty
Lg shine activation of bluetooth
I have the same problem and I have a US one. I have a bluetooth that I should be able to connect with it and it does not find my bluetooth. It could be the phone. I am going to ATT to find out if they can pair it.
Nov 05, 2008 | LG Shine KE970 Cellular Phone
your board is faulty and will need to be exchanged by lg for free
Sep 08, 2008 | LG KU990 Viewty
Problems With my Lg CU720 BlueTooth
When i try to connect bluetooth lg shine ask me to set bd address. how i set it's bd address?
Jun 24, 2008 | LG Shine KE970 Cellular Phone
Bluetooth address
i too have that problem
Jun 21, 2008 | LG KU990 Viewty
hi i spent hours trying to solve this ...
finaly i found this site http://forum.gsmhosting.com/vbb/showthread.php?t=508796
follow the instructions and you should be fine :)
its was virus free when i used it.
Jun 03, 2008 | LG KU990 Viewty
LG Shine KE970 Cellular Phone Logo
1,999 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
