Question about AT&T Blackberry Curve 8300 Smartphone
Red light goes on then turns off. phone will not turn back on.
I have replaced the battery and when I do so the red light will go on for a few seconds and then turn off. The phone will not turn back on. Pls. help!
  • 5 more comments
  • Anonymous Nov 10, 2008
    Mine did that too and I freaked out. I put in a wrong password and couldn't get back into my phone. It was going to "wipe" my data so i took out the battery and it wil not turn on.
  • Anonymous Feb 05, 2009
    my phone does the same thingbut it turns rightback on
  • NeiN11 Feb 11, 2009
    Was updating apps when cable adn connection went off (storm). Now red light blinking and pholne won't come on, USB port not recognized...HELP!
  • piinkberri Feb 14, 2009
    I am having similar issues. The radio is turned off on my curve and every time I try to restore the radio, the phone shuts off. I tried replacing the battery and do not know what else to do. HELP!
  • Anonymous Mar 20, 2009
    my blackberry turns off and restarts on its on> usually when on the phone
  • Anonymous Mar 23, 2009
    my phone shut off on me when i was sleeping and wont turn back on...the red light flashes though. this happened to me before and it turned on eventually but this time it wont.
  • BlackBerry Rescue
    BlackBerry Rescue May 11, 2010
    Have you tried to reload the device via the Application Loader? This will probably the fix also too.
There are only 2 options:
- faulty firmware: reload the firmware with App Loader in Blackberry Desktop Manager
- damaged motherboard: then the only thing you can do is to replace the motherboard, but this is usually more expensive than buying another one
Posted on Feb 17, 2009
My phone is doing the same thing. From what I understand this is a Blackberry issue. It's not the battery or anything else. I just removed the Facebook app from my phone because I also read that it takes up a lot of space.
I've had my Curve for almost a year now and never had any problems. Then the past 3 days it has a low battery by the afternoon. Today it turned off by itself and would not turn back on.
Posted on Oct 24, 2008
Why does my red light flash on my z998 but wont turn on
try pulling the battery out,Just leave it out a few seconds (count of 30). And unplug power(charger) cord from your phone. Then put the battery back in and press the power button.
Feb 08, 2015 | AT&T GoPhone Z998 4G No-Contract Cell...
My blackberry z10 wont turn but red light flashes
I'm not an expert on phones, but it sounds to me like that is the low battery light that is flashing, so I must ask, have you charged it recently? if not, try that and then after a few hours try turning it back on.
I hate to sound stupid, but a lot of phones will flash a red light if the battery is too low for it to turn on. so it is worth mentioning.
Feb 20, 2014 | Research In Motion BlackBerry Z10 Unlocked...
Samsung Savyy wont trun on. it blinks red
please use other samsung battery same as your phone if not the issue is on the phone it self.
Dec 20, 2013 | Cell Phones
My phone will have the red light flashing but wont turn onwhen i charge but if i take the battery out it turns on but goes off and on over and over
sound to me like your chip inside the phone is bad. or you just might have to replace your battery. my charges on it's on without the charger plugged in. i will pull the battery out and wait a few minutes, put it back in and it's still chrarging lol. mine is my battery so yours probably is to.
Oct 28, 2013 | Straight Talk Huawei Ascend Y Cell Phone
Hi i have an experia ant the littli led light on the top stays on red all the time
Hi.
The little red light means your battery requires charging.
Plug in the charger and allow it to charge.
It should change colour to orange when it has over 15% charge in it and then turns green when it is 90% charged.
If it still stays red dispite being fully charged. Try removing the battery for a few seconds and then replace it again.
I hope this helps.
If your phone is fully charged and it still has a red light, then take it back to the shop you acquired it and get a replacement.
It means you have a hardware fault.
Mar 09, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
Jan 28, 2011 | HTC Touch P3450 Smartphone
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
I have an "old" phone of that is a gift from
A red light indicates not enough power for turn on, the battery is either completely depleted or dead. If the light does not change to amber after a few minutes of charge, the battery needs to be replaced with a new one.
Dec 26, 2010 | T-Mobile Dash Smartphone
Red led light is flashing while charging and it won't turn on
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
May 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Red light
On page 30 of the manual a red light states "Solid red-battery is not installed or is over discharged. Flashing red-battery very low(less than 10%)
Mar 23, 2008 | T-Mobile Dash Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
4,701 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
