Question about Ricoh (RW7063A) CD-RW Burner
Ricoh RW7063A Can I get a driver that will work on Vista?
Can I get a driver that will allow this to work on Vista?
I need help with a windows 7 driver for SP-c210SF. does anyone know where I can find a driver that works?
There isn't currently a Windows 7 driver available for this machine. You can attempt using a Vista driver or the driver may be available embedded within the Windows 7 software. Worst case, you can use a generic driver such as the HP Laserjet 4 driver. Using this driver should get you printing but may not allow machine specific functions. It is available from within the Windows 7 software.
Dec 04, 2009 | Ricoh Aficio SP-C210SF Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Drivers for RICOH R5C475 for Windows VISTA
It doesn't look like Ricoh made a Vista driver for this card. According to Geeks.com, the R5C475 is only compatible with Windows 98, ME, 2000, and XP.
Mar 15, 2009 | Ricoh R5C475 Serial Adapter
RICOH GX3050N and Windows Vista
You can find the driver on the Ricoh site. here is the link:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/gx305/gx305en.htm
Mar 14, 2009 | Ricoh Aficio GX3050 GelSprinter
Network printer installation problem
Are you using the proper Windows Vista Driver? You can't use the XP version...here's a link to the download page:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/cl7000/cl7000en.htm
Jul 11, 2008 | Ricoh Aficio CL7000 Laser Printer
Caplio R40
Try to install the software anyways, even though it is not Vista Compatible, meaning it wasn't tested or certified for use with Vista. If that doesn't work, try to visit Ricoh's website to see iff they have a driver compatible with the Ricoh Caplia R40. If that doesn't work, email Ricoh and ask what they can do to help you.
Dec 17, 2007 | Cameras
Ricoh (RW7063A) CD-RW Burner Logo
46 people viewed this question
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
