Question about Brother ML-100 Typewriter
Some uppercase letters are not printing correctly
When trying to print uppercase letters, certain letters are not recognizable. If I take the daisy wheel out and reset it again, it will work once or twice if that letter is typed, but then goes back to doing the same thing again. Typical letters with this problem are the T, C, L, P. Any suggestions? Would this be the wheel or something in the typewriter?
  • coastline Nov 12, 2008
    Everything seems to be loaded correctly, so I just replaced the daisy wheel that was causing the problem. The typewriter itself is working fine. Thanks for your help.
    Scholar:
  • 183 Answers
Make sure ribbon and corr. tape are in properly and not interfering with the free movement of the printwheel. ribbon and tape should be between the two metal fingers and the cardholder. make sure the two fingers are not bent down into the printwheel. check the "fingers" on the printwheel to make sure they are straight. with the printwheel out of the machine, push the printhammer forward and release it to make sure it snaps back freely. if these seem to be okay then it could be a problem with the p/w motor or motherboard, and would need professional help.
Posted on Nov 03, 2008
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Oct 26, 2009 | Brother ML-100 Typewriter
Wrong letters are printed
The Daisy wheel is probably in wrong..reinstall it until it spins to the home position. Its either that or an adjustment to the print wheel motor.
Oct 07, 2009 | Swintec Office Equipment & Supplies
I have a really old SD 660 and I no longer have manual. It is printing great but it is not typing correct letter for example when you type a it prints the letter p and so on?
Remove the printwheel check for bent spokes, look for debris in that area, try it without the correction tape, check that the correction tape is dry not tacky, also check to see if the pitch selection isn't in PS proportional space. If allis good the homing pawl spring is probably broken, you need a tech.
DickyO
Jun 26, 2009 | Smith Corona Office Equipment & Supplies
I have a Brother WP-2000 word processor and when I changed the Daisy Wheel the letter typed is not printed and another letter or symbol is printed. How do I align the daisy wheel so this does not happen
Turn the typewriter off, remove the daisy wheel.
USUALLY there is a small rectangular slot in the daisy wheel that points up.
Insert wheel and turn on.
Make sure your spacing is NOT set to PROPORTIOAL SPACING
Nov 20, 2008 | Brother Office Equipment & Supplies
Print hammer not in alignment with daisy wheel and it wont print .is there an adjusment i can make?
I have turned the typewriter on and off and it still is not printing the correct letters.
Oct 16, 2008 | Brother GX-6750 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Brother ML-100 Typewriter Logo
102 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
