Question about Kenwood VR-407 Receiver
Remote works intermittently
Sometimes the remote works and other times it doesn't. I have changed the batteries on more than on occasion and it doesn't seem to have an effect.
    Scholar:
  • 47 Answers
Hi!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:first try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com.
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Posted on Oct 09, 2008
I have a functioning remote but the tv sometimes just stops reponding or responds intermittantly. In my case when the tv stops responding to the remote, I unplug the TV, leave it for 30 sec and plug back in. That seems to take care of it.
Posted on Feb 01, 2009
On 4 occasions we found the door open! Installed in November 2014!
Sometimes the down force is set too light and the door opens as it gets to end of travel. Are you sure it was closed and stopped when you found it opened? Or just heading down as u drove off. Also, the wall remote if wired could have a staple that penetrated the wiring, that shorts out and opens door intermittently.
Apr 21, 2015 | Building Materials
RCA Home Theater RT2906 doesn't respond to Remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Have you tried new batteries?
May 16, 2011 | RCA Audio Players & Recorders
Remote start will work intermittently. have tried from 10 feet to 50 feet with same results. won't start. went to dealer they stated its because the range is not too high for the factory installed system....
Have you changed the battery in the remote?
Do so, then re-introduce the remote to the remote start system following the manufacturer's instructions, and the problem should be solved.
Dec 26, 2009 | Toyota Camry Cars & Trucks
1993 Honda civic speedometer & odometer work intermittently
the only thing that is related is the d4/rough gear changing
speed/ rpm malfunction is caused by your speed sensor on the trani (common problem) change it
Sep 20, 2009 | 1993 Honda Civic 4 Door
Remote dead.
A common problem is that people tend to be rough on remotes. Dropping a remote is the most common cause of failure. This will sometimes crack the circuit board. Depending on how the board is damaged it may not be serviceable.
Sometimes, but on rare occasions, the Infared transmission diode becomes defective, or the frequency crystal fails. A TV service center can fix this if they can have the parts. Normally remotes are not supported by the manufactures for service. They will tell you to order a new remote from their parts distribution.
Jerry G.
Jul 20, 2009 | Samsung DVD-P181 DivX DVD Player
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
Apr 25, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Electrical or computer problem; intermittent
You might have a problem with the body contro module, have it tested for codes.
Nov 21, 2008 | 2003 GMC Sierra
Kenwood VR-407 Receiver Logo
442 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
