Question about Brother CS-8150 Computerized Sewing Machine
Is the timing off? Stitches are loose no matter what setting it is on I can't spin thread on bobbin tight and it makes a strange clicking sound during stitching
  • 46 Answers
Sounds like it's time for a checkup.
Posted on Oct 25, 2008
Stitches to loose
You need to tighten the bottom and top stitches both. First, tighten the bobbin slightly. Now, tighten the top stitches the same amount of pressure as the bobbin. The attempt is to have both the bottom and top stitches exactly the same so the final stitch ends up in the center of the fabric. Observe the stitch and readjust if necessary.
Oct 08, 2017 | Sewing Machines
Hi. I just bought this machine and I am having trouble with my bottom stiches. I have tried every remedie but the stiches is too loose
Read this hope it helps
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
May 19, 2016 | Sewing Machines
What are the dial for tension to be set at.
Hello Michele, I would check to see if the machine is threaded correctly. Your problem could be in the thread take up arm and thread tensioner.
Aug 24, 2015 | Singer 2662
What should the tension be on for this machine?
Most of the time if the bobbin thread is coming through on top it means that the bobbin thread is too loose and/or the top thread is too tight and is pulling the thread too much. check and make sure that there isn't anything in the top tensioner that could be increasing the tension like lint. Good luck.
Feb 17, 2015 | Singer CG-590 Commercial Grade Sewing...
Elastic thread pulled too tight in Janome Sewist 525S
I would say your tension spring is shot on your tension assembly. replace it.
Mar 27, 2017 | Janome Sewist 525S Mechanical Sewing...
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I have a Singer 2010 and it stopped winding the bobbin. I purchased a new bobbin case in hopes that would fix the problem, but it did not. I am also having problem balancing the stitches. No matter how I...
Sounds like the machine needs retiming and the bottom gear checked undewr the bobbin case area, I can attach timing instructions if you email me drivewithken@blueyonder.co.uk
Mar 07, 2010 | Sewing Machines
Brother CS-8150 Computerized Sewing Machine Logo
51 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
