Question about Panasonic CT-36HL43 36" TV
Vertical adjustment My TV cuts off part of the picture at the bottom, making almost impossible to read scrolling news items.
  • Panasonic Master
  • 508 Answers
Is the very bottom of the picture compressed or folding over? if so, it's a deflection/coupling issue to the vertical stage of the yoke circuit, due to leaky/shorted diodes and leaky electrolytic capacitors. Check the PCB for cracks, dry solder joints, and the IC itself; replace if necessary.
Check EVERYTHING in the vertical output stage.
Posted on Feb 21, 2011
  • Demonic-2011
    Demonic-2011 Feb 21, 2011
    It's always a good idea to thoroughly inspect and/or replace the vertical IC, as these can develop weird fault symptoms. The jungle IC should not be the problem here, but check it also to be sure. Only consider replacing the whole TV if the service centre tells you (free quote - insist on this first if you find nothing unusual) that it will be expensive, and not economical to repair.
Buy a new telly
Posted on Oct 09, 2008
UN46EH5300 adjust screen size to get whole picture and closed captions
Sounds like you have it on zoom setting. Go to the picture menu and scroll through the options. Start with 16:9 and try others if this doesn't work. If you've already tried this, you may have to go into screen setting and manually draw the picture in horizontally and vertically - but make sure you've got it on 16:9 and paused on a typical picture before you mess around with these settings.
Aug 22, 2014 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
Sony lcd projection tv vertical adjustment KF-50E200A
Try changing the settings for the video formats, widescreen, regular, and all that. There are angle mirrors in the back of the tv that direct the projected image on the screen. The mirrors are positioned such that if, says, a piece of a metal bracket or something falls down inside the projection area, it'll fall right against the projection lens and block the image. Open up the back of the tv and follow the light path from the screen backwards to its source and make sure there's no debris in the projection path.
Sep 17, 2009 | Sony KF50E200 TV
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Entire image will not fit on screen
The set may be overscanning. You will need a service tech to evaluate this for you. It is possible that there are some failed components that can cause this problelm. It is also possible that there are some adjustments that can be done.
The first step is to find out if there is a problem or not. It is not very good practice to over adjust a set to compensate for a fault condition. Then there will be bigger problems soon after.
An experienced TV tech who is familiar with your set can make some diagnostics to know where the fault is occuring.
Jerry G.
Feb 17, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Graphics are cut off.
First, have you made any adjustments to the tv other than from the setup menu? If not I have the service manuals for the tv in pdf files and would be glad to send them to you. Let me know I have the same tv and corrected the same problem. v/r, Scott
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Bottom of picture is cut off
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Jan 01, 2007 | RCA F27440 27" TV
Sansui - BOTTOM OF SCREEN CUT OFF
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
Sep 12, 2006 | SansuiS2001 20" TV
Panasonic CT-36HL43 36" TV Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
