Question about Sharp AR-5316 Advanced Digital Imager Copier
Error code E7
We have a used copier that we bought at an auction. we've lost the business card that came with it and also had the "user" numbers to operate the machine. Can it be reset. Also, when we were able to use copier kept getting E7 error code. Can you help???? Please! Thanks
Dawn
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is there another set of numbers after the E7?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check your exposure lamp to fix this
Posted on Oct 11, 2008
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 36 Answers
E7 is a primary code, you have to press print key for you to see the sub-code of E7
Posted on Jul 07, 2013
E7 ERROR CODE
when the E7 code comes their is sub code u can view it by pressing start key then we can guest how ever i think this is coming from scanner ccd or chick ribbon cable connecting to the mother board from c c d
Jan 14, 2014 | Toshiba e-Studio 161 Copier Copier
1I am was using Sharp ARM155 printer/copier. i got the error message on printer that "Error Code [E7-11]. Please refer the user guide". please tell to me how do solve the problem.
E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
Jul 29, 2011 | Sharp AR-5316 Advanced Digital Imager...
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
I bought this gestetner 3227 copier at a auction but it has user codes on it and I don't know how to get past them to use my copier, can you help?
Yes, you can delete the User codes.
But first see if you also have administrator code. You have to know that first and then you have clearance to change the User codes.
All these instructions are in the user manual. You can download for free on the website of RICOH. The equivalent of your machine is AFICIO 220.
Jan 28, 2011 | Gestetner Office Equipment & Supplies
Cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
May 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Will not scan, copy or print error code e7-11
Replace the Mother Pwb the part number is CPWBN1460DS51..... Good Luck
Jun 02, 2009 | Sharp AR-M350N Copier
C180 copier error code E7
The e7 code is for the sorter problem. you can either call for service 18002435556 or just remove the sorter and use the copier without it.
Oct 19, 2008 | Pitney Bowes C180 Copier
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
E7
reset it first if you can all copier error code can be reset if the copier does not reset check the exposure lamp
Oct 02, 2007 | Sharp AR-156 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
328 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
