Question about Canon PIXMA MP460 All-In-One InkJet Printer
No paper My printer gives me a message that there is no paper. Paper tries to feed, but does not. It tries to pull it on the right side, but cannot grab and pull the paper in. Any ideas?
    Brigadier General:
  • 6,966 Answers
A possibility is the presence of a foreign object lodged between the feed rollers and the bar/plate. Pls try to visually inspect the area where the paper initially feeds into, use a flashlight. It is possible that the printer has paper clip, stapler, bits of paper, tape or something stuck anywhere in the feed area. Other possibilities are:
  • too thin paper;
  • paper a bit damp and sticking together, try fanning;
  • dirty feed rollers.
Incidentally, the paper sensor is actually a small lever activating a switch. It would be a small bar that moves down when a stack of paper (or even a single sheet) is placed on top of it. Try locating this lever and exercise the switch underneath by depressing the lever a few times.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 09, 2008
  • Louie  Role
    Louie Role Oct 10, 2008
    Hi again,
    Any updates?
    Guru:
  • 1,894 Answers
Give one paper per feed and try.
it must detect the paper.
if the paper is getting pulled in one side it must be OK with sensor.
just a proper cleaning work may be required
Every time I try to print something, the paper doesn't pull from the tray straight. It pulls to the left side and crumples the sheet of paper so that it can't feed through the printer.
You do not state the type of printer so it is difficult to give exact instructions, but I know what your problem is. Something is stuck in the paper path on the right hand side, hence the reason is skews to the left because the left side is able to advance and the right is hitting the obstacle. If your printer has a paper drawer, turn off the power, remove all cords and the cartridge. Pull out the paper drawer and then carefully stand the printer on it's back so that you can see where the paper goes as it comes out of the tray. You will likely find your problem right there. If you can repost with an actual model I can give you a much better idea of how to find a paper jam but these instructions should help you.
Mar 26, 2011 | Office Equipment & Supplies
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Tip
Paper does not feed properly
I was sick of the dreaded please load paper message I pulled the printer apart cleaned every thing to no avail. There is a roller on the right hand side where you feed the paper in. A small raised section behind the roller is used to pinch the paper between it and the roller. When this wears the paper will not feed. TO FIX Push a small piece of plastic it must be slippery (I used a 2 cm * 6 cm off an old xray) behind the roller Then use sellotape to hold it in place. No more dreaded load paper messages
on Jul 27, 2007 | Lexmark X5270 All-In-One InkJet Printer
When feeding my paper it keeps pulling the paper
You need to replace the feed rollers. One side is probably worn. You should be able to buy a rebuild kit for it. Try ebay.
Nov 02, 2009 | Lexmark X2600 InkJet Printer
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper feed problem
Sound like something foreign is in paper path
Dec 24, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
66 people viewed this question
old marine
old marine
