Question about Logitech Audio Players & Recorders
Logitech S-220 Speakers
I have a new computer and have plugged in my Logitech S-220 speakers the orange power light is on but I have no sound - can you help?
I am running VISTA ULTIMATE 64-bit
    Scholar:
  • 54 Answers
Hi cfbruce,
First, double check your startup/user's guide cd and retrace your steps just to rule out the small stuff, you know, jacks are in tight, if its a 5.1 surround system the center speaker may have an on/off volume knob. Your speakers may have a player utility that needs to be configured i.e your utility may be set to headphones. Select the configuration that most resembles your speaker setup i.e headphones, cpu 2 speaker, surround, 5.1 or 7.1 etc.. and last, but not least, make sure your system is not muted. This will drive you crazy if you don't know the system is muted.
I hope this helped a little, if not , hit me back, we have other options.
Thanks for using FixYa.com
Sincerly, cyyyd7
Posted on Oct 09, 2008
  • 477 Answers
Did you plugin the speakers in the green input? back of your computer?
try to go to controlpanel, and then sounds and check your settings.
good luck
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
I have installed windows 7 on my (old) computer, and now my logitech x 220 speakers don't work
click start control panel hardware and sound manage audio devices playaback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list windows7
hope this helps
Jul 10, 2011 | Logitech X-220 Computer Speakers
My logitech z-640 speakers arent working and i have no clue why first id like to know where to plug in the plugs in my laptop theres a geen,orange,black cord i have a microphone,headphone and some other...
The different connectors are for 5.1 surround audio, and are for different speakers with your system.
  • The green connector is for your front-right/front-left speakers
  • The black connector is for your rear-left and rear-right speakers
  • The orange plug is for your center speaker.
Most laptops do not have support for 5-speaker audio, so if you want to test each individually, you will need to plug them in one at a time and test playing sounds through them.
Hope this helps,
Dec 17, 2010 | Logitech Z-640 Computer Speakers
WHERE DOES THE ORANGE BLACK AND GREEN CORD GO?
Sorry,there is no "orange,black and green cords" on Logitech x-530 computer Speakers. Every RCA has it`s own color (yellow,black,white,red).It shouldn`t be hard to plug them in.
Nov 02, 2010 | Logitech X-530 Computer Speakers
How do i attach the speakers to my computer
The manual for you speaker system is located here;
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=8793&p_sid=jIAa2a-j&p_lva=8040&section=troubleshoot&crid=439&lt_product_id=211&tabs=1%2C3%2C2%2C5&p_search_text=X+530
On page 2 of the manual it says that all of the speakers plug into the subwoofer, then the subwoofer is pluged into an ac power supply, then # 4. on page 2 of the diagram shows that the Audio input cable to your PC is the green, black & orange plugs!!!!! YAY!!!
If you do not have a Dolby 5.1 sound card with green black and orange plugs, you will have to buy one. The can be had for a little as $15....
Thanks,
James
-----------------please vote 4 thumbs up 4 me!!!--------------------
Apr 24, 2010 | Logitech X-530 5.1 Speakers
I just bought a logitech 5.1 x-540 for my uncle. It worked fine; but just last week, when my uncle turned on the speaker, there was no power (the green light on the speaker didn't turn on). I tried to plug...
Could there be an electrical short in the speakers line?Could you return them for a refund? Also did the speakers come with the logitech computer system? Have the speaker system bench tested.Then go out and buy a new pair.
Feb 16, 2010 | Logitech X-540 Computer Speakers
HOW TO HOOK UP ALL MY X-530 LOGITECH SPEAKER ON MY PC
You'll only be able to get true surround sound utilizing all the speakers if you have a sound card with multiple outputs (usually color coded as Green, Black, and Orange). Plug the satellite speakers into the subwoofer and run the three input wires (Green, Black, Orange) to your multi-source output.
If you only have one output on your PC (common), you should just connect the green wire and press the "matrix" button on the system. This will just duplicate the sound output into the other channels but is not "real" surround sound.
Hope that helps.
Feb 07, 2010 | Logitech X-530 5.1 Channel Speaker System...
Logitech Z-5500
Well you have some options, you can either live with 2 speakers and change the settings back to default. Im assuming the colors you have are orange black and green. black= the surround sound speakers. orange= center and subwoofer. green=right left front
Now if u want true surround sound then you need to buy a new card that had all the ports for your speakers.
Oct 21, 2008 | Logitech Z-5500 Computer Speakers
Logitech mm50 speakers
if no light came from the speakers then something is corrupted inside them .. you have to check the power source and power cable of the speakers first ... if everything is fine then the speakers are corrupted from inside
Dec 28, 2007 | Logitech Inc MM50 Portable Speakers iPod...
Speaker hook up
Methinks he joined an extra to one of the fittings you will need to do the same. When you join up the four let one hitch a ride so to speak on one of the connections.
Aug 20, 2007 | Logitech X-530 Computer Speakers
349 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
