Question about Microsoft Excel for PC
Excel formulas If you are using multiple sheets in an Excel file, is there a formula to calculate numbers on one sheet in a selected cell and then have that info sent to another sheet that is in the same file?
Jhgfjg
Posted on Oct 25, 2008
  • 477 Answers
Hello
yes it is.
example
sheet1
A1 (50)
A2 (50)
sheet2
(A1)=
"=Sheet1!A2+Sheet1!A1" <-this is the actually code in sheet2 column A1
ok let me explain
in A1 and A2 in sheet1 you got 50 and 50 like numbers.
in A1 on Sheet2 you have = sheet1 a1 + sheet1 a2.
did you get it?
dont know else how I should explain it...
good luck
Posted on Oct 09, 2008
Please help me to solve the circular reference in 2013 excel file which stop opening the file. Thank you
first start excel and click on formula tab -->Calculation options -->Manual
excel1-yi4l5i2224qkwob0czw2k0fe-5-0.pngNow open file, if asks for update formulae, say no.
Now select entire sheet, select formulas tab--> Error Checking -->Trace Error.
excel2-yi4l5i2224qkwob0czw2k0fe-5-2.png It will locate all error containing cells, now rectify the error save it reopen in excel to see if problem is solved.
Apr 12, 2017 | Microsoft Excel for PC
What is the easiest way to link several formulas from seperate worksheets?
pen both the sheets in the same window as:-
1. View Tab-->New Window --> Arrange All --> tiled
2. Open first sheet in first window and second in second window
3. now create formula simply by clicking in corresponding sheets and selecting cells.
Alternatively you can use following format of addressing:-
1. SheetName!CellAddress (Same Workbook)
2. [WorkbookName]SheetName!CellAddress (Different Workbooks)
For more clarification please mail on ali_zulfikar@yahoo.com with screenshots.
Jul 16, 2014 | Microsoft Excel for PC
Want to copy formula into multiple excel sheets
why not? however, you can also insert an apostrophe (') at the start of the equation before copying the entire formula so that the formula will be treated as a text thus preserving all cell references. dont forget to remove the apostrophes after you have pasted them though for the formulas to work again.
Jul 29, 2009 | Computers & Internet
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
Feb 11, 2009 | Microsoft Excel for PC
Excel formulas
type in "=" and then go to the cell in the 2nd sheet and click on the cell that contains the value you want carried to sheet 1. Then drag copy the forumula in sheet 1 to all the cells you want it to relate to. Now, if you place a value in e.g. A1 of sheet 2, then that same value will appear in A1 of sheet 1.
Good luck.
Sep 13, 2008 | Microsoft Computers & Internet
Exel 2003
You can refer to cells that are on other worksheets by perpending the name of the worksheet followed by an exclamation point (!) to the cell reference. In the following example, the AVERAGE worksheet function calculates the average value for the range C1:C10 on the worksheet named Marketing in the same workbook.
default.aspx?assetid=za010939481033 Refers to the worksheet named Marketing default.aspx?assetid=za010939491033 Refers to the range of cells between C1 and C10, inclusively
  1. Click the cell in which you want to enter the formula.
  2. In the formula bar (formula bar: A bar at the top of the Excel window that you use to enter or edit values or formulas in cells or charts. Displays the constant value or formula stored in the active cell.) default.aspx?assetid=za060515351033, type = (equal sign).
  3. Click the tab for the worksheet to be referenced.
  4. Select the cell or range of cells to be referenced.
Jan 01, 2008 | Microsoft Office Standard for PC
Excel Coordinates don't show up in Formula Bar
Heyo. I have had this problem before too. This procedure prevents the cells that contain the formula from being edited.
  1. Select the range of cells whose formulas you want to hide. You can also select the entire sheet.
  2. On the Format menu, click Cells, and then click the Protection tab.
  3. Select the Hidden check box.
  4. Click OK.
  5. On the Tools menu, point to Protection, and then click Protect Sheet.
  6. Make sure the Protect worksheet and contents of locked cells check box is selected.
Good Luck!
Wayne
Dec 28, 2007 | Computers & Internet
Duplicacy in excel sheet
Since you are searching the data by the phone number , first select all the data in the spreadsheet and sort it in ascending order by the phone number.
Then, assuming you have 5 columns of data A through E, and the phone numbers are in column E, with row 1 occupied by column headings, use the following formula in cell F2=IF(E2=E1,"Duplicate",1)
Drag this formula down column F till the end of your data
Select the entire data and do an auto filter
In column F filter the data by Duplicate and delete all these rows
What remains should be unique data
Dec 19, 2007 | Computers & Internet
Microsoft Excel
Dear jois you can make a link from one sheet to other sheet by making a hyperlink. When you will click one cell in first sheet it would shift the sheet in the cell you will fix it.
You can follow this process:
  1. Select a cell that contains the external formula
  2. Highlight the File path and sheet name in the Formula bar, eg; 'L:\Daves\[Book2.xls]Sheet1'!
  3. Push Ctrl+C then push Enter.
  4. Select the range of cells you wish to change the reference in and go to Edit>Replace.
  5. Select in the Find what box and hold down the Backspace to ensure you do not have a space.
  6. Push Ctrl+V.
  7. Do the same in the Replace with box and then edit the file path to the new one needed.
  8. Click Replace All
if that has helped you please press 'fixya'
Nov 29, 2007 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
186 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
