Question about Microsoft Wireless Laser Mouse 5000
Erratic pointing My Mouse 5000 has begun to point very slowly and erratically; sometimes the pointer refuses to move at all. Also the red "light" or "laser" that was visible on the underside is out. Are the two conditiosn related and how do I fix?
  • 3 more comments
  • Anonymous Oct 23, 2008
    Plz some help...
    I have exactly th e same problem...
  • dlovelock1 Nov 10, 2008
    Same here. No light, very erratic movement. Makes gaming impossible and web browsing very frustrating.
  • dabutcha99 Jan 09, 2009
    same problem, going to try yooperbud's solution
  • Anonymous Mar 18, 2009
    Yooperbud, did you read the problem. It is the mouse. Not the keyboard or printer. I have the same problem. This mouse is horrible. As for the light, it is an invisible laser on the 5000. So, there is no light. Just a horrible mouse.
  • FLMike May 04, 2009
    Vertical movement is more erratic than horizontal. A patterned mouse pad helped, but not enough.
After experiencing the same issue for a few frustrating hours, I read here the theory about the required distance accuracy between the sensor and the surface.I used to be able to use mice (any brand) on a simple piece of paper or directly on (wooden) surfaces. Not with this "laser mouse..." I was about to try the "tape-with-a-hole" solution, but before trying that I simply threw a heavy, thick magazine with a glossy back-cover on the table and tried again. Worked like a charm. The heaviness of the magazine (I think) lent the "flatness" which I believe is the real required solution. I'm not sure if the glossiness played a role here...
Posted on Jul 07, 2009
Solution!
I hated this mouse ever since I got it. My old optical mouse would work on any surface, but this one would not. On most surfaces that I use, it was horribly jerky.
After a lot of aggrivating hours of using this mouse, I discovered that the problem is that this mouse is Very picky about the distance that the laser sensor is from the surface that it is being used on. If you use the mouse on a surface that is not perfectly flat, it is really jerky.  If you use this mouse on your pants leg or other curved surface, the surface gets too close to the sensor. The laser light is reflected at an angle that doesn't hit the sensor.
My 2 cent fix was to take a few layers of Scotch tape, punch a hole thru them about the size of the laser hole, and then put the tape on the mouse, lining up the holes. Try to use just enough layers of tape to match the thickness of the 4 oval glide pads on the bottom of the mouse. My mouse now works perfectly.
Microsoft should have put a glide pad around the sensor hole, instead of putting the silly the "Microsoft Laser Technology" sticker there.
If the tape doesn't last, I might pilfer a glide pad from one of my old mice, and drill a hole through it.
Posted on Jun 17, 2009
    President:
  • 8,637 Answers
Go to Control Panel and click on Keyboard. Keyboard properties will appear, then click on SPEED tab, adjust the various items as you desire. Also the printer properties has tabs to set your keys to function as you would like them to.
Hope this helps. Bud
Posted on Jan 08, 2009
After buying the tamper-proof star key needed to take it apart, and disassembling the mouse, seeing nothing was wrong, I found this:
http://support.microsoft.com/kb/321122
The problem seems to be fixed with Windows 7, btw.. I'm able to use my Logitech or Microsoft mice interchangeably.
Posted on Jul 03, 2009
Windows 8.1?
Not sure what you mean but a possible problem with erratic mice is the mouse pad. A coloured pad sometimes reflests the light in an erratic fashion that causes the pointer to do unexpected things. Try it without a pad or one with no patterns.
Aug 31, 2014 | HP X4000b Bluetooth Mouse
Kensington PilotMouse 72129 Erratic movement across the screen, even with reset and new batteries
Microsoft has a knowledge base article on erratic mouse pointer movement that may help. As you can see in this article, there is more to it than uninstalling and reinstalling the mouse driver. Microsoft Support on Mouse Problems.
As I've said, it's possible that something has corrupted your mouse driver. You can either 1) re-install the driver, or 2) roll back the driver. Either one of these may help. To roll back your driver in Windows XP, go to Start --> Settings --> Control Panel --> Mouse. Click on the "hardware" tab. Select the appropriate pointing device, and click "properties." Click the driver tab, then select "roll back driver."
Under the "hardware" tab, there may be more than one mouse. If this is the case, select the one that is not used, follow the settings above, and then select "uninstall." Or, you can go into Control Panel --> System --> Hardware --> Device Manager, and remove the device under "Mice and other pointing devices
Dec 14, 2010 | Kensington PilotMouse 72129 (DH72129)
How to stop razer pointer from moving
Stop moving the mouse.
Ok seriously, if a laser mouse is on a reflective or glossy surface such as a varnished wood desk or a magazine the mouse can do erratic things...
Feb 17, 2010 | Razer Pro Solution V1.6 (RZPROSV16)
Originally my Track Point driver was and IBM type. My pointer started to be erratic and uncontrollable and I update the driver but a Lonevo driver was downloaded. However, the problem with my pointer is...
check the track point driver version and then try to search the driver using google...or try one of these sites
1)laptopdrivers.com 2)en.kioskea.net
Dec 19, 2009 | Computers & Internet
Mouse point has it's own mind.
If it's an older style mouse, it might just need cleaning. If it's optical, sorry, I have no ideas.
Aug 05, 2009 | Computers & Internet
Wireless trackball mouse pointer frequently won't respond
Just took it apart and cleaned the ball thanks anyway
Dec 30, 2008 | Atlus Sticky Balls for PSP
POINTER FREEZES THEM MOVES THEN FREEZES DRIVING ME NUTS. THANKS
When this behavior is observed when using a Logitech product withinWindows® XP, it may be caused by a feature within Windows called"enhanced pointer precision". This feature may conflict with Logitech's software, causing the erratic movement. Enhanced pointerprecision became available in Service Pack 2 and therefore is notapplicable in any version of Windows® XP without Service Pack 2installed. For more information on enhanced pointer precision,please click HERE. If this link does not work, then you should go to Microsoft and search for Knowledge Base article 895550.
Please see these articles from the Logitech database for possible troubleshooting tips as well:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=970
Troubleshooting: Erratic Cursor Movement in Optical Mice and Trackballs
Mouse cursor is uncontrollable or behaves erratically
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Interference with Cordless Products
Download latest version of software
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 27, 2008 | Logitech Cordless Mouse
Jerky mouse
Try using a different Mouse Pad or surface. This is a cause of jerky and erratic mouse movement.
Hope this is of some help. Bud
Oct 07, 2008 | Logitech Cordless Mouse
MX 5000 Keyboard/Mouse combo
sljs
have a read of there help guide here, click number 6 might be some help.
Logitech > Support > Find Answers
riz.
Feb 17, 2008 | Logitech Cordless Desktop MX 5000 Laser
Erratic behavior
I just sprayed my dad's lens cleaner on one end of a Q-tip to clean the lens of the mouse and dried the excess fluid with the other end of the Q-tip. WORKS GREAT :)
Nov 10, 2007 | Targus AMU18US Mouse
Microsoft Wireless Laser Mouse 5000 Logo
709 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
