Question about Acer NSK8458AN Keyboard
Acer keyboard brand new computer but my keyboard keys -question mark, apostrophe are all coming up as french symbols such as ??. any button i can push to make this stop - question mark thanks heather
  • 4 more comments
  • mymysharona Oct 11, 2008
    Hi there- I am having the same problems on my Acer laptop AND my wireless keyboard that I have attached. HELP!!!
  • Anonymous Oct 15, 2008
    I have the same issue and so does my girlfriend and we both use Acer laptops! How the heck do I turn these french symbols off????? :(
  • CharMH Oct 23, 2008
    I have the same problem.
    When I hit the shift key that has the Greater then or Less then symbol on it, I get this ' & "
    And if I use the shift with the Parenthesis keys I get this ¨¨ & ç
  • trevorjohnfo Nov 05, 2008
    can;t make question mark just this; éééééééé++++++
  • Anonymous Feb 05, 2009
    I have the same problem, but changing my keyboard setting to English UK and removing the Canadian ones does not solve this. I`ve somehow jammed the keyboard onto the French characters and can`t get them off.
  • Anonymous Feb 21, 2009
    The solution did not work.
  • 20 Answers
I had the exact same problem. I contacted Acer support and they sent me this solution that worked for me;
Please do the following steps to resolve this issue.
1. Click on Start > RUN
2. type intl.cpl in the Run box, and then press ENTER.
3. On the Languages tab
4. Click the Details button.
5. In the Settings tab, under the Installed services section, click the Add button.
6. In the Input language list, click the language that you want; English (United States) [or English (Canada)].
7. In the Keyboard layout/IME list, click United States-International, and then click OK.
8. In the Settings tab, under the Default input language section, change the language to English (United States) - United States-International [or English (Canada) - United States-International].
9. Click the Apply button and then the OK button.
10. In the Regional and Language Options dialog box, click the OK button to close the dialog box.
11.Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout; English (United States) appears [or English (Canada)].
Posted on Apr 05, 2010
  • 3 Answers
Go to control panel - clock language and region - change keyboard and other methods - change keyboards... - click on Canadian French then remove it.
That is how I fixed it.
Posted on Oct 21, 2008
When I strike the apostrophe, quotation marks (or double appostrophe)appear. When I Shift + apostrophe, double quotations appear. Same thing happens with the tilde key. So far just these 2 keys...
Sounds like a defective keyboard. I seen issues when pressing a button it will trigger another key to be pushed or nothign displays at all. Try replacing keyboard since they are relatively cheap. othersie maybe a software issue
Mar 03, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
I cant use the right apostrophe key
most likely its the connector on the motherboard, if its not making connection on certain pins on the connection, then same thing will happen, try can air on the connection area, see if that helps.
Feb 01, 2010 | Acer NSK8458AN Keyboard
Symbols gone crazy
The keyboard appears to be defective, but if you replace it and you still have issues, then the matrixing chip on the motherboard is bad and you will have to change the motherboard as well. Let me know, and vote.
Jul 02, 2009 | Acer NSK8458AN Keyboard
When I use the shift key and the question mark , I get the French e symbol instead of the question mark. How do I fix this
Hi there
thi should be quite a simple fix for you
click start then control panel , regional settings , advances you should now be able to see what keyboard layout you are using click add then add the correct one for your language and remove the incorrect one
restart pc and test
Regards AL "alstech"
May 29, 2009 | Acer Computers & Internet
Bilingual keyboard
There is a small green Fn button near the start button you will have to use this with shift to use the green keys if you are in multi lingual mode, if you only use the laptop for french you can also change the regional settings for the keyboard to Just French and then they will work just by using shift.
Hope this helps FixYa,
May 19, 2009 | Acer Aspire One PC Notebook
Computer is locked in the green symbols of the keyboard
TO SHUT OFF the green keys, you need to disable the multiligual or French keyboard layouts. For Windows 7:
click CHANGE KEYBOARDS... etc.
.......for example, by clicking on a keyboard name (ie. US or and UNITED KINGDOM for example) and then clicking PROPERTIES to the rtight, you can see the actual key layout.......
On the list of installed languages, click anything multiligual or French, and then click REMOVE found on the right-hand column
click APPLY
click OK
Then you've removed the French.
Otherwise you have to click the LEFT ALT key and then the LEFT SHIFT key to swich back and forth between the green keys and the white keys.
Jan 04, 2008 | Acer Aspire 5500 5570-2609 Laptop
? or ?
Double check that everything is US-english for the keyboard. go to START>>>control panel>>>regional and language options. Make sure everything in the first screen is go to the LANGUAGE tab go to DETAILS. look to see what the keyboard language is. If set on US change it to something the settings go back in and change it to US then save again. Check everything else make sure its US.
Nov 27, 2007 | Acer NSK8458AN Keyboard
Messed up keys
try hitting the left alt and the left shift button together, then try it out by pressing shift question mark. I had the exact same problem and i think you can alternate between french and english keys by hitting these two buttons together.
Jan 18, 2007 | BenQ X805 Wireless Desktop Companion Pro...
Acer NSK8458AN Keyboard Logo
1,927 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
