Question about Car Audio & Video
Car wont start
I have a 2003 Lincoln Ls with 76,000 miles on it and last nite it needed a boost to get me home from work, but when I got to my daughters school it would not start or take a jump. I have interior lights,horn, radio but it wont turn over. I was able to get battery checked and it is a good battery per (Advance Auto) Please if someone can help I am recently divorced and scraped for cash
  • 92 Answers
I would check all the connections to the battery, sometimes corrosion will cause this problem. Also check where the other end of the battery connections join to the car. Could also be a bad solenoid or starter.
Posted on Oct 09, 2008
Testimonial: "It was dead on, it was the starter..Pricey but it fixed the problem and I appreciate the response and assistance"
What caused my Lincoln ls to surge while foot was on the brake?
My 1st guess or 1st instinct would be to say it's a computer software issue, becasue I can't think of anything mechanical that could cause this type of issue. I suggest instead of asking here, you contact your car dealer or manufacturer.
Jul 28, 2014 | 2003 Lincoln LS
As I'm driving the car slows down automatically from 50 to 10 miles an hour and the wrench comes on. The manual indicates that the engine has defaulted to a
My 2003 LS did this last year. My fix was a new computer. The cost somewhere around $1,400. Not saying you have the same problem.
Aug 09, 2012 | 2003 Lincoln LS
2003 lincoln ls v8 rattles when first started
It's your Cat. I promise you I hads the same thing happen to mine and was told it was just my heat shild but if that was the case then it would raddle all the time I thought then when I got a new cat it all stoped
May 04, 2012 | 2003 Lincoln LS
My Lincoln Ls died for no reason,restarted over and over but wont stay running.Tank has plenty of gas.Car has been kept in excellent condition but does have over 200,000 miles.Love my Lincoln,has been a...
You have a Fuel Delivery Pump & a second Fuel Transfer Pump
in the fuel tank
The tank is large & under the car ,under the rear seat
Have to remove the exhaust system & drive shaft
The Fuel Pump Relay --is in the Battery Junction Box (BJB) as well
as the Fuel Pump Motor Diode
There also is a (REM) Rear Electronic Module
I recall that has a variable speed pump regulator
or whatever
There are even more players there as well
Very complicated system ,that you have no way to even
start on yourself
Doubtful even a repair shop could do much
I have a 2004 LS and all the Factory Manuals & Wiring
Diagrams. Without them your done
Check fuel pressure at rail on engine Should be about 42 lbs
Aug 03, 2011 | 2003 Lincoln LS
When was the last tune up? may need coil pack, plugs, air filter, oil, motor mounts could have gone bad. If you have not done any service to the vehicle a standard tune up of replacing ignition parts is key to do before troubleshooting any issue.
Good luck.
Aug 02, 2011 | 2003 Lincoln LS
My 2003 Lincoln LS sometimes misfires or bucks while driving.......What's the cause of this?
Most likely 1 bad COP Ignition Coil
You will loose about 1 or 2 a year on an LS
Also your EGR Valve will only last about 5 years
Hopefully you changed the front 2 --O2 Sensors
at 100,000 miles
Jun 06, 2011 | 2003 Lincoln LS
My 2004 Lincoln ls has been acting up. First it was running rough so I changed coil on 4 and then 2 seven monthes later after which car ran great. Now on two occasions when triing to start alarm goes off...
I don't think going to AutoZone for codes is of much
value to anyone
Obviously your LS don't miss on 4 cyl or have 4 bad coils
You didn't need to replace any coils except the one that fails,
which is 1 or 2 a year on that car.
You most likely have one really bad coil that sets all kinds
of codes.
You can buy one new coil & walk it every couple days until
you get to the bad one or go to a repair shop with an oscilloscope
and the correct inductive coil adapter.
You need to use the correct OEM style plugs (NGK)
were the motorcraft mfg.
Check alternator output with a scope & make sure
the battery isn't more than 4 years old. Todays cars
are sensitive to voltage,current,resistance and grounds
Clean the MAF Sensor (crc maf cleaner)
At 100,000 miles replace front O2 Sensors
May 17, 2011 | 2004 Lincoln LS
2003 lincoln ls.... harsh reverse......transmission has been rebuilt & pcm has been reprogramed......
Was the Solenoid Shift Valve & Pressure
Pack, in trans replaced ?
You do realize that your transmission should have lasted
many more years.
They fail because the fluid is not changed
every 30,000 miles
Mar 24, 2011 | 2004 Lincoln LS
Our 2001 lincoln ls was running fine, then all of a sudden now it wont start. we have replaced the battery, and everything else turns on, it is just hard to turn the key and it wont start--and it was all...
I would love to answer this question but I am having the same issue. I have a 2000 LS with the V8..replaced the battery about 2 weeks ago and last night I went to go home and it won't start. All the bells ring when I turn the key but when I turn to the right to "start" position, nothing. No clicking, no noise at all. I called the Lincoln dealership and we went over the alarm light "not flashing" and shifter position. They have no advice other than "tow it in".
The vehicle had been running fine.
Feb 22, 2010 | 2001 Lincoln LS
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
