Question about Hitachi 53FDX01B 53" Rear Projection Television
Red horizonal convergence tilts instead of adjusting evenly.
While attempting to adjust the convergence on my Hitachi 53FDX01B the red convergence will align vertically but when I attempt to align it horizontally it tilts from left to right instead of aligning evenly. For example if I press up on the remote to bring the red convergence up, the right side will go up but the left side will go down, this problem is most noticeable on the sides of the screen, when the right side is aligned the left side is completely off of the green and blue convergence lines. I would like to attempt this repair myself as I've had experience with computer repairs, however I've never attempted a TV repair before. Any help or advice is greatly appreciated.
  • 61 Answers
For your hitachi unit one of the convergence IC is bad along with couple of low value resistance on
the convrgence board.
Good luck
Dals123
Posted on Oct 09, 2008
Hitachi 60EX01B, horizontal picture is off along with the red convergence. Would like to leave set on and take front panel off and adjust accordingly, instead of unplugging and plugging back in. Says 200v...
You should be careful as dangerous voltages are there, if red convergence is off a lot likely bad convergence chips. A lot of the chips will either be good when cold or even drift when hot.
Note that this is a older set and the twenty or so surface mounted caps in the digital convergence which store the adjustments may be failing---usually if good convergence when hot.
Fixed more than a few of these sets.
Oct 15, 2012 | Televison & Video
Convergence Adjust
It means probably one of the two convergence ICs has blown
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
How do i adjust the lights on my hitachi 50gx30ba tv
It sounds like you are having a convergence problem--see attached photos for examples----
If so, with the original remote go into customer menu and select convergence (Some Hitachi sets have a button up front called magic focus--if there engage to see if it helps) in the menu you can also attempt to adjust this--if it will NOT MOVE either up/down or left/right for either red or blue---convergence circuit has a problem.
Let me know what you find.
Mar 22, 2012 | Hitachi Televison & Video
Hitachi 53FDX01B - Green line bent during convergence adjustment? Th epicture quality is really bad and it appears there is a problem with the convergence (There is a green line [north & south] that...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Oct 09, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 53FDX01B 53 in has green line in the middle and in the corner
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony2_bing.gif, Samsung,JVC2_bing.gif,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif, Hitachi,Mitsubishi,Zenith2_bing.gif and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull bb0cf99.png
Apr 20, 2010 | Hitachi 53FDX01B 53" Rear Projection...
The picture is in 3d and i cant turn it off?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Red convergence not aligning
Did you replace the resistors. If not you should have bought a complete kit from www.TvRepairKits.com instead of just the 150's.
Jan 30, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Poor picture quality on Hitachi model # 53fdx01b
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 20, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
202 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
