Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Hoover steam vac dual v makes humming noise and nothing else.
Used the vac to clean half the carpets in my bedroom and it started to make a slight noise so i shut it off and dumped the old water out and replaced the container and turned it back on and now all it does is make a low humming noise like it is froze up or something, so I cleaned out the brushes and filters/screens and washed everything and let it set for a moment then tried to start and it started with the normal sounds for about 5 seconds and went back to the humming again please offer some advice.
  • Anonymous Oct 25, 2008
    I got the same problem. The steamer is only 3 months old also. Just makes a humming noise when you turn it on. Also, when you tilt it back, the brushes do not spin.
    It does release water though when you pull the trigger.
Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
Posted on Oct 21, 2008
I have a model f7411900 steam vac from Hoover and it started making a loud noise like a broken belt does in a vacuum. Does this have a replacement bely
Open the product, make sure first that it is not something stuck inside. If it is a belt, check with amazon. Just make sure that you have the correct model.
Aug 24, 2016 | Hoover F7411900 Maxextract Dual V Carpet...
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
How do I switch from tools to flooe on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi Cherie! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Jun 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How do I switch from tools to floor on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac smoking
Your problem sounds electrical in nature. I would take it in for evaluation / estimate of service.
Apr 22, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
356 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
