Question about Sport & Outdoor - Others
Uniden bc855xlt i have lost my manual; need to know how to get out of lockout mode please respond asap ty
Http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC855XLT%20(Manual).pdf
This location has the manual in a FREE pdf format. I got this scanner yesterday in a grage sale. Almost all the places wanted $10-$16 for a download. The resolution on this FREE manual is not the greatest...but what do you want for free. LOL. Hopes this helps.
Posted on Nov 29, 2009
Hold the Lockout button down until you hear two beeps....all channels are now unlocked.
Posted on Mar 10, 2009
How do you unlock channels on scanner
Hi Lori,
Many times, you need to switch to MANUAL mode (out of scan) and step thru each channel. The display will indicate if the particular channel is locked out by symbol or text. Pressing ENTER or LOCKOUT (depending on model scanner) should toggle a locked out channel back into the scan - and a scanned channel into lockout.
Without knowing your scanner model - it's difficult to tell you exactly how to do it. If my suggestions do not work, reply and include the brand and model number so I can get you the exact steps to solve your problem.
May 29, 2013 | Uniden Radio Communications
Stuck in lockout mode
radio shack pro 97 scanning receiver,
Jul 17, 2012 | Uniden BC60XLT-1 Handheld Scanner
Uniden dect 6.0 _cordless phone. is stuck on silent mode ,lost the manuel need to know how to get it off ..phones wont ring
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to download a copy of the manual.
Sep 21, 2011 | Uniden DECT 6.0 Cordless Phone
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
Hi i have a regency D300 thrity channel scanner and i need to no how th lock out the weather band channel
put it in manual mode and scroll to the desired frequency that you want to lockout. You should be able to just press the lockout button while in manual mode and it will lockout this channel. Then just simply press resume or scan and it should be resolved.
Jan 21, 2010 | Uniden BC72XLT Handheld Scanner
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
Cant get off lockout
If a channel does not have a frequency programmed into it, it will display 000.0000 and the L/O icon. Programming a frequency into the channel will automatically release the lockout.
To release lockout from a single channel, select that channel and then press the L/O key.
To unlock all programmed channels, select all frequency to ON, then press and hold the L/O key until the scanner responds with 2 beeps.
For a full reset of the scanner, press and hold the 2, 9, and HOLD keys while powering up the scanner. The reset will take about 3 seconds, and will be confirmed with a display of CLEAr. NOTE: this will reset the scanner to its original factory settings, and will delete everything that you've programmed into it.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
I hope this helps. Please contact us again if you have any other scanner problems.
BillB
Dec 24, 2009 | Uniden BC72XLT Handheld Scanner
My uniden bc80xlt handheld scanner has lost all button functions. The radio still scans and picks up frequency broadcasts, but NONE of the buttons work. What is going on here?I have no" manual" function, I...
Sounds like you may have accidentally pressed the "LOCK" button. If there's a "key" icon showing, press the LOCK button at the bottom left of your keyboard, and hold it in until the icon disappears. In case you need it, here is a link to the operating manual for your scanner:
http://www.uniden.com/pdf/BC80XLTom.pdf
Nov 22, 2009 | Uniden BC80XLT Handheld Scanner
BEARCAT BC855XLT
doanload a manual from uniden.com for the bc-600xlt. It's the same manual
Jun 20, 2008 | Uniden BC246T Handheld Scanner
Uniden BC72XLT compact scanner
Hi, this is from the manual,
Locking Out Channels
You can increase the scanning speed by locking out channels that have a continuous transmission, such as a weather channel. To lock out a channel,
manually select the channel, then press Func +L/O.
L/O appears.
Note: You can still manually select locked-out channels.
To remove the lockout from a channel, manually
select the channel, then press Func + L/O.
L/O disappears.
I hope this helps you out,,, Mechanic
If you need a manual, go here.
Jan 22, 2008 | Uniden BC72XLT Handheld Scanner
Sport & Outdoor - Others Logo
375 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
