Question about Dell 5110cn Laser Printer
Dell CLJ 5110
Need transfer roller reset instructions.
  • TicaGirl Oct 20, 2008
    Thank You so much for all your help.
Pop the lens cover off of the transfer roller, clean all the toner debris out of there and replace the lens, put clear tabe on it, and you are good as new!
Posted on Feb 24, 2009
    Novelist:
  • 188 Answers
Hi TicaGirl,
There is no reset for the BTR.
When the error message is displayed, simply remove the old BTR, install the new BTR, and the error message goes away.
There is no circuitry or counters involved. The BTR collects waste toner, and when it is full, the obtical sensor that "reads" through the BTR becomes obstructed, and thus causes the error.
I have seen some people try to dump the waste toner and clean the sight glass, but really the BTR should be replaced, and the error will clear.
Thanks,
Posted on Oct 18, 2008
How do I reset a dell inspiron 5110 to factory settings
Hi Anonymous,
Let me know the reason why you are trying to do a factory reset like are there any issues with the computer.
You may use the below link to take the computer to factory state:
http://dell.to/1B8to5P (Windows 7 only).
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Mar 09, 2015 | Dell Inspiron Computers & Internet
How to reset roller kit warning on hp laserjet
Hi the HP Laserjet CM6040 how to reset the document feed roller go to administration then go to reset menu then in reset menu scroll down until you see the new document feed roller select either yes or no. Hope this helps
Jun 10, 2014 | Premier Hp - ROLLER KIT CLJ MFP CP6015...
WIl not print correctly
If it is faded, it could be the transfer roller. I've had great success with simply periodically cleaning it, then getting a good printout. See my solution for this already posted: Check out this solution to the HP Color LaserJet CM1312nfi Laser Color...
Otherwise, the other issue I had late last year was that it needed a new intermediate transfer belt (part #RM1-4436-000CN). You can find a good deal on one, and the instructions for replacement are on page 156 in the service manual: http://www.feedroller.com/Store/Service%20Manual/HP-CLJ-CM1312-MFP-Manual.pdf
It's not the hardest replacement ever, but needs 2-3 hours depending on skill, and a little patience.
Mar 28, 2014 | HP Color LaserJet CM1312nfi Laser Color...
I've getting the "Replace transfer roller" message
  1. reset count in printer menu
  2. clean the optical sensor
Mar 15, 2011 | Dell 5100cn Laser Printer
Error 59.99 for HP laserjet 3550
Thank you for contacting Fixya with your printer inquiry.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=411173
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 59.99.00 Error Displayed on the Control Panel Issue
When faced with a 59.99 error, we have found additional ways to solve the issue since the service manual was written.
Error: 59.99.00 Description: An error occurred in the secondary transfer engaging mechanism. Solution
Follow the troubleshooting steps below:
  1. Fuser seated improperly. Reseat the fuser.
    NOTE: You may hear grinding sounds from the right, rear of the printer associated with this specific failure also.
  2. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor. (PS16, part of paper pickup/feed assembly)
  3. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid. (SL4, part of paper pickup/feed assembly)
  4. Faulty feed motor. Replace the feed motor. (M1)
  5. Faulty DC controller PCB. Replace the DC controller PCB.
  6. If the 59.99 error only occurred after removing and reinstalling the paper pickup/feed assembly, what may have happened is that the secondary transfer engaging solenoid SL4 may have become dislocated. See figure below. Verify position of tab on top of solenoid.
    Figure (See Link)
    h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/.../1/343540.em
    Parts associated with this fix:
    Pickup/Feed Assm - RM1-0765-070CN).(Includes solenoid & sensor)
    DC Controller PCB (RM1-0510-000) DC Controller, CLJ 3500/3550
    Primary Transfer Roller Engaging Motor (M-5) RK2-0139
    Drum Motor (M-3) RM1-0733Drum motor - Provides power to turn cartridge drums
    Delivery Motor (M-2) RK2-0138
    Feed Motor (M-1) - RK2-0137 Located on lower left front of main right side plate assembly
    Secondary transfer engagement sensor. (PS-10) (Part of Pickup/Feed Assembly)
    Secondary transfer engaging solenoid. (SL-4) RK2-0145-000CN
    Formatter Assembly Q1319-67903
    Parts sources:
    http://lbrty.com/Products/HP/parts_hp/pnC3500.html (Very Good Parts Vender Catalog) http://www.feedroller.com/Store/clj3500.php (Parts Vender) http://www.laserprinterservices.com/hp3500/hp3500.html (Parts Vender) HP Customer: To order HP computer parts and printer parts by phone please call 1-800-227-8164 , Monday-Friday, 7:00am to 7:00pm CST.
    Thank you for using FixYa. Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 16, 2011 | HP Color Laserjet 3550 Printer
Need to replace transfer roller dell 51110 do no have a new one but i need to print some more pages. Can i reset the printer in any way
The answer will be in the users guide or owners manual. I am assuming that your model is 5110CN You can get that here: Dell Documentation
Look for the section about replacing the drum or transfer roller. There will be a section about resetting the page or drum counter.
Good Luck!
Feb 05, 2010 | Dell 5110cn Laser Printer
REPLACE TRANSFER ROLLER
Replace transfer roller means you need to order a transfer roller for your
dell printer. your best bet is to go to www.dell.com and order the trasnfer roller for your printer.
thanks adi
Jan 15, 2010 | Dell 5110cn Laser Printer
Is transfer roller available separately. dell only sells it with imaging drum
it does work we have both models and the transfer rollers are interchangeable between the 5100 and 5110.
Oct 02, 2009 | Dell 5110cn Laser Printer
on google search for Dell 5100cn user manual... you will see a pdf download available. It will give you step by step instructions.
Jul 28, 2008 | Dell 5100cn Laser Printer
What is the hard reset for Dell 5110cn
I have a dell 5110 cn laser printer and the transfer roller just went out.. How can I re-set this since I do not have a replacement roller. but i need ot order. Thanks
Apr 19, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Logo
1,544 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
