Question about Garmin GPS
I am a hillwalker and use a Garmin GPSmap 60CS on the hills but of late it turns it self off after 7/8 minutes where as before the GPS would stay running for the duration of the walk [ up to 5 or 7 hours ]. The other functions are working ok ,just the GPS now powers off 7 or 8 minutes ...hoping you might have some answers
  • 2 more comments
  • smallfarmer Oct 09, 2008
    I am a hiker and use a hand held out door Garmin GPS unit [GARMIN GPSmap 60cs] when nanvigating on the hills.. but lately the GPS switches off after running for about 7/8 minutes and has to be re started again...where as before the GPS would run for up to 8 hours depending on the length of the hike/trip...still looking for answers
  • smallfarmer Oct 10, 2008
    the answers that i am getting are useless as they are NOT dealing with my problem...
    this servise is a con and waste of my MONEY
  • smallfarmer Oct 13, 2008
    Got NO answer
    To my problem ;I am a keen hiker/hill walker and use an out door ;hand held gps unit [ Garmin Gps MAP60cs unit ] on the hills.
    Of late the unit has started to power off and cuts out after running for about 8/9 minutes and has to be re started again;.
    only to cut out once more.
    Before this it would run for up to 10 hours depending on the length of the hike/trip.
    The other functions of thr GPS are working fine.
    Hoping yo get some answers this time around as I have no answers so far
    not really but i was looking for an answer and i got an answer...not a great answer but at least you gave it a shot and for that thanks
  • 171 Answers
Sorry you have received the typical lame answers from these guys. They are not supposed to answer questions they are not familiar with, but have not figured out they are useless and frustrating to the customer. Again, Sorry.
There are a few things that can cause this,
1. Battery Charge Cycle - If the battery you are using is the factory rechargeable, then do this. Run the battery pack all of the way to empty. When the unit powers off, turn it on and keep turning it on until the unit will not power up any more. Now , place on the charger and allow to charge overnight, undisturbed. Although these supposedly do not have memory, they do. If these are your own rechargeable batteries. same procedure, just outside of the Gamin unit.
2. Check the battery type selection in the setup menu. Maybe this somehow was changed and it is not setup for NiMH but Alkaline.
3. Using WAAS, backighting or frequint beep tones can significantly reduce your battery life. To find out maor about this or for instructions on how to change the settings, please see page 39 of your user manual or click on the link below.
http://www8.garmin.com/manuals/GPS60_OwnersManual.pdf
For you edification, there is an software update to your unit and I just wanted to make sure you w3ere aware of it. If you have not loaded this up to your GPS 60, click on the link below.
http://www8.garmin.com/support/collection.jsp?product=010-00322-00
Also, one footnote, and I am sure you already know this, but,
With Battery Save mode, the GPS updates its position less often. For example, in standard mode, it updates every second (on average). In Battery Save mode, it updates every 3 - 5 seconds, depending on how you are travelling.
Posted on Oct 13, 2008
  • 81 Answers
Hi.
I think its a hardware issue and nothing cant be done about it.
I advice you to get the device checked.
We cannot provide hardware support.
If you have any other questions do fell free to ask me.
Regards
Faraz
    President:
  • 2,712 Answers
Have you tried inserting new batteries? Garmin GPSmap 60CS uses two AA located at the back of the unit. You can use alkaline or NiMH batteries.
DO NOT USE LITHIUM BATTERIES, BECAUSE INITIAL VOLTAGE OF NEW BATTERIES MAY EXCEED 1.5v EACH, CAUSING THE UNIT TO TURN OFF. (This could be the source of your problem.)
To install the batteries:
1. Remove the battery cover by turning the D-Ring 114 turn counterclockwise and pulling the cover loose.
2. Insert the batteries, observing the proper polarity. A polarity diagram is molded into the battery compartment.
3. Reinstall the battery cover by aligning the back cover with the unit and turning the D-Ring 114 turn clockwise.
Remove the batteries from your GPSMAP 60CSx when you do not expect to use the unit for several months. Data is not lost when batteries are removed.
Hope that helps! Please don’t forget to "Accept" the solution if it helped you in any way, or leads you to a fix.
Thank you for using FixYa!
Cheers!
IrishDruid
Posted on Oct 10, 2008
  • Swilin Sampson
    Swilin Sampson Oct 10, 2008
    * Details from user manual page 47.
    IrishDruid
  • 749 Answers
Alkaline batterys are going to last shorter in cold weather. replace them with lithium if you haven't already.
    Genius:
  • 1,011 Answers
Dear,
try it by clearing or formatting ur SD memory card and then try again .. do a concentration towards battery too.
regards,
dont rate it until it fixes or helps
  • SALMAN NASEER Oct 11, 2008
    dear,
    did u find anything helpful from my suggestion..
    regards,
    Genius:
  • 3,422 Answers
HI,
The problem is with the battery.It is not a software issue.You will have to replace your battery and your problem will be solved.One more thing are you sure your charger is working properly because if it is not then your battery will not receive proper charge.So i suggest you to connect it to the PC and allow it to charge for 5-6 hours.If the device hols power for hours then the problem was with one of your cigarette or the wall charger.
Posted on Oct 09, 2008
  • Priya darshan Oct 09, 2008
    If you need anymore help let me know.
    Please take a moment to accept the solution.
    Genius:
  • 1,124 Answers
I think that you have a problem with your batteries. May be need to be replaced.
  • How do I save batteries?
  • Posted on Oct 09, 2008
    • Pablo Csaky
      Pablo Csaky Oct 10, 2008
      Please first take a look to the links provided by us. There are a lot of info and troubleshooting about your garmin.
    • Pablo Csaky
      If your unit has good batteries and your unit shut down indicates that there was a "data abort"
      Almost all these problems are caused by software bugs that can and will be fixed by a firmware version.
      Genius:
    • 1,913 Answers
    Hello, are you missing the map of costa rica or can you clarify the problem?
    Maps for N250W
    https://buy.garmin.com/shop/shop.do?cID=134&pID=9121
    link broken, click here
    http://buy.garmin.com/shop/shop.do?cID=134&pID=9121
    Then select maps from page http://www.retrevo.com/support/Garmin-250W-GPS-manual/id/2946dj098/t/2/
    Let me know if you need anything else. the maps are available at the garmin website for sale. if the map you need is not listed contact garmin
      Guru:
    • 1,894 Answers
    I think you would have made some settings change.
    and hence please try a factory reset. and it must be fine
    • dewan nafees ahmed Oct 09, 2008
      also try to format your SD card once and the use it
      things may become normal
      to do a full reset
      1- Turn off unit.
      2- Press and hold the bottom right corner of
      the screen.
      3-
      While still pressing and holding bottom right corner, press and hold power
      button and
      continue holding both until a white
      screen appears (may take a couple
      minutes) with a
      black dot.
      4- Follow the on screen directions (pressing
      various dots that appear on the screen) and
      y
      our unit will be back to the day you first got it.
    Keeps restarting
    try useing the webupdater at garmins website to upgrade the software on your gps, this may solve the problem let me know if you need further assistance.
    http://www8.garmin.com/products/webupdater/howtoinstall.jsp
    Jun 12, 2008 | Garmin GPSMAP 60CSx GPS Receiver
    Have a Garmin gpsmap 60 cs unit that needs repair, but Garmin doesn't cover this unit anymore. Who does repair this model?
    Hi!
    Garmin will make out-of-warranty repairs to your unit, but the labour rate is SPENDY! ($110/hr)
    http://www8.garmin.com/support/outofwarranty.html
    Welcome to the age of disposable electronics.
    Sorry I couldn't have been the bearer of better news.
    Good Luck!
    Dec 30, 2010 | Garmin GPSMAP 60CS GPS Receiver
    It has just been refurbished!!!!! Now when I try to turn it on the screen flickers once every second!!!
    Get it straight back to Garmin. Personally I would look for a replacement as most Garmin software returns we get back in the shop end up being returned time and again until the customers get fed up and demand a new one..
    Oct 06, 2009 | Garmin GPSMAP 60CS GPS Receiver
    Garmin GPSMAP 60CS displays wrong date
    mou exoun dvsei ena gps to opoio mesa einai ola sbismena.
    prospathw na tou perasw ena ellhniko xarth alla den mporw...
    xreiazomai help.......
    Feb 03, 2009 | Garmin GPSMAP 60CS GPS Receiver
    I have cganged settings on my GPSmap 60CS and it now display only waypoints and not complete tracks. Can anybody out there advise?
    On the Map page press Menu. From the options shown choose Setup Map. Go to Track tab and make sure Saved Traks is not set to OFF.
    Jan 12, 2009 | Garmin GPSMAP 60CSx GPS Receiver
    The GPS cannot get satellite signal. It only displayed "acquiring satellite" considering that we are in open fields with clear sky.
    Shut off the Receiver...
    Press and hold Page + Menu + Power...
    Then select "Yes" to erase all user data...
    Leave it on with a clear view of the sky without moving for about 30 minutes to acquire the satellites.
    Nov 28, 2008 | Garmin GPSMAP 60CS GPS Receiver
    GPSMAP 60CSx
    You can't turn the navigation back on with this method. You must once again highlight the waypoint you want to navigate to in your Fine>Waypoints screen and then press the "Go to" highlighted button on the screen.
    Jun 25, 2008 | Garmin GPSMAP 60CS GPS Receiver
    Gpsmap 60c can not acquire satellites even when left outside for 15 minutes in a place where it usually has no problem. Problem happened overnight.
    Are there any there any satellites listed on the satellite overview page?
    What is the GPS SW Version listed by the unit?
    0.00?
    Mar 12, 2008 | Garmin GPSMAP 60CS GPS Receiver
    GPSmap 60Csx power up problems
    I had the problem where I ended up disassembling the Garmin and adding a small piece of plastic to the on/off button. For some reason the push button on the top does not reach the one on the circuit board.
    Oct 19, 2007 | Garmin GPSMAP 60CS GPS Receiver
    GPS Logo
    112 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    Steve
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
