Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Shark steam mop
I have a purple shark steam mop model #s3101c the unit heats up but will not produce steam
  • 22 more comments
  • Anonymous Dec 01, 2008
    I have a purple shark steam mop, that won't steam even though the light is on. Please help!
  • eksrag Dec 03, 2008
    Just purchased the Steam mop and the unit will heat but not produce steam
  • rpdpro Dec 06, 2008
    same problem.....:[
  • Hypnojo Dec 09, 2008
    I have the same problme and cannot remember which TV channel I bought it from! Can you help? It is less than a year old.
  • Anonymous Jan 15, 2009
    I have only used Shark Steam Mop a few times and powers, heats, but won't steam.
  • kdrivals Jan 17, 2009
    Used my shark steam mop once and now it wont steam. It heats up but no steam. Any solutions?
  • juliamarie1 Jan 29, 2009
    mine heats up but wont steam, the water does not get hot, but the outside of the steamer does. mine is going back!
  • Anonymous Feb 03, 2009
    euro-pro shark steam mop-gray/purple vacuum - Problem heats up but no steam comes from it.
  • gmcaulay Feb 03, 2009
    euro shark steam mop gray/purple vacuum
  • audiojim Mar 02, 2009
    No steam at very first try and got the same answer from customer service but doesn't help.
  • Anonymous Mar 15, 2009
    UNIT HEATS UP BUT NO STEAM IS RELEASED AT ALL!!!!!!
  • mariner63 Apr 24, 2009
    My Euro Pro Shark Steam Mop Gray/Purplue.
    Stopped steaming only releases water in to the pad
  • jones4real May 11, 2009
    This product lights up but doesnot steam
  • trina_KS May 14, 2009
    Same problem. Unit gets very hot, but no steam is produced.
  • Anonymous May 22, 2009
    gets hot on outside but no steam
  • blab9091 May 23, 2009
    My Sharp steam mop is not even 6 months old. I used distilled water only as recommended and it stopped producing steam
  • Anonymous Mar 13, 2014
    On/off switch will not turn on.
  • Anonymous Mar 14, 2014
    bissel steam mop no steam
  • Anonymous Mar 15, 2014
    steam mop
  • Anonymous Mar 16, 2014
    when plugedin lights comeon but no steam
  • Anonymous Mar 21, 2014
    Shark does not steam. Maybe it is clogged?
  • Anonymous Mar 28, 2014
    additional details for great white sharks
  • Anonymous Mar 29, 2014
    can not change setting on steam mop
  • Anonymous Mar 30, 2014
    Steam not generating
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
The most likely reason it creates steam but won't push it out the mop is due to a broken tube inside. I took mine apart and found one of the neoprene tubes was broken. there is a spring inside the tube that came out as well. the spring is used to keep the hose from collapsing when the water gets hot. Very similar to what is done with a car for the radiator hoses.As of yet I haven't been able to find anyone that sells the neoprene tubing.
Posted on Oct 26, 2009
I bought a shark 3101 steam mop. When I fill the tank, the water just runs out the bottom before I can use it. How do I fix this leak?
Posted on Apr 10, 2011
  • hopeinhiseye
    hopeinhiseye Jul 14, 2012
    take out the 6 screws on the side if the machine and there are also some hidden where the filter goes and once open you'll see immediate a rubber tube split or torn. i used air hose line for a air filter for that you would use with any ordinary fish tank. (sorta like a adaptor) it worked great, just cut the shredded part of the tubbing out first obviously and i sealed it with Shoo Goo lol. stuff works on EVERYTHING. i was determined bc i had picked the Shark van n steam Mop up at a garage sale for 20 buks. good luck
    Problem Solver:
  • 8 Answers
Well got one brought it home worked for five minutes. Went back to walmart exchanged my Shark.Only one box left,looked opened but nothing seemed out of place till I got it home.Must have beeen a previous return somebody was short a funnel for their meth.lab(lol).Now warranty or not have tod to take it apart and see.There is a line that looks like it has a tendency to come off it has a spring inside it.Looks like it just blew apart because of pressure (poor design) Going to reattach it see what happens.
Posted on Jun 13, 2009
I called customer service, they claim the reason it wont steam is there is a air bubble in it! well i emptied the water, started over and NO steam! it may work for one of you though.
Posted on Jan 29, 2009
    also mine does not get the water hot, but the outside of the steamer gets hot!
Steam mop s3101c does not dispence steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
l;'
Jan 08, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Shark Steam mop model #S3101CO does not produce any more steam from the bottom of the unit. Worked fine last time I used it, the base still feels warm but no steam?
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Dec 30, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need a replacement handle modle S3101C
Look under the manuals link... they sell replacement handles...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
Mar 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop model #S3202 is no longer heating and producing steam
The heating element may have died or there is an obstruction...
heatman101
Jul 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop
heatman101
ab
May 29, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The unit heats up but produces no steam
heatman101
vvb
Mar 31, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Turns on but won't produce steam
heatman101
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
7,097 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
