Slimline storage heaters with no switch to turn on/off - how do you turn them on? have taken off the front panel but can see no switch/override - the electric cable comes straight from the wall into the heater
  • 417 Answers
The principle of electric storage heaters is that they take in electricity at night through a central time switch (normally owned by the electricity supply company and usually not controllable by the user).
There should then be a main switch/ fuse box to control the heater circiuts, check for such a box and that it is switched on (This would normally be sited near the electricity meter).
There should be an isolator switch next to each heater but from what you say this is not the case.
There should be some controls on each storage heater marked INPUT with a dial from 1 to 6 or similar then another marked OUTPUT or BOOST.
When you have ascertained the fuse box is on and the heater controls are set to maximum you then have to wait overnight for the heaters to warm up.
Posted on Oct 09, 2008
Currys Essential Slimline CDW45W10. Why is water not getting hot?
These seem like the siemens/bosch type. There is a heater relay that can go bad. Its in the front panel. Check the relays in the front panel for bad solder or burn marks.
Sep 02, 2015 | Dishwashers
1997 Ford Taurus front defrost not working
. Air won't blow out of the floor or center vents just defrost ? Do you have manual or automatic climate control ?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob mounted on the A/C-heater function selector switch, which is part of the integrated control panel.
  • The function selector knob has the following positions: OFF, MAX A/C, A/C, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST. The A/C-heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318). Refer to the Vacuum Control Diagram , System Airflow Schematics and Vacuum Control Chart .
  • Two internal, single-pole electrical switches are also controlled by the A/C-heater function selector switch. The combination of these electrical switches controls the electrical supply to the A/C clutch and heater blower motor switch (18578).
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • Vacuum Control Motors The vacuum control motors (18A318):
    • are located on the A/C evaporator housing, A/C recirculation air duct and heater air plenum chamber (18471).
    • direct system airflow to the vehicle interior as determined by the remote climate control module or manual override.
    • The five-passenger seating configuration has an additional vacuum control motor mounted on the heater air plenum chamber to control airflow to the rear seat A/C register (19893).
Jul 09, 2017 | Ford Cars & Trucks
Dishwasher motor running constantly
did you try to pull the plug , maybe the pump or a relais kept being activated
Jan 02, 2014 | Dishwashers
Back seat heater fans do not blow
the front control is the override for the rear. check the position of the front fan switch
Nov 15, 2013 | 2003 Chevrolet TrailBlazer
I need an instruction manual for a comfy air wall heater
how do you ste up the comryfair slimline panel wall heater
Jan 08, 2012 | Heating & Cooling
My beko tumble dryer drcs68w does not heat up, i have taken the back off and checked all the connections between the heater and the control panel,if i do a reset by holding the cancell button for aprox ten...
its a trip switch, if its tripping then there is a fault with the element, it is either clogged up or shorting out when it heats up. i would think it needs replacing. becareful with dryers as there have been a lot of beco products over the years.
May 30, 2017 | Dryers
Help! I can't get the water heater to go on! I KEEP TRYING to set the dial, but it's not working
If I understand correctly, you have the WH40 water heater timer.
If timer dial will not rotate, then use manual override to turn on circuit to water heater.
If manual override will not move back and forth, the tripper pin might be wedged against the lever.
Lift and rotate dial out of way.
If manual override does not click back-and-forth, then timer is probably bad.
If manual override clicks, but water heater does not turn on, then check electricity.
If you need more help, post a comment and I will respond
Oct 28, 2010 | Intermatic WH40 - Water Heater Time Switch...
How do you tell if you have rear a/c. My compressor needs replaced and I need to know which one too get. With or without rear a.c I have a 1997 Dodge Caravan se with the 3.3.
Look on the front heater air conditioning control panel. If it has a four position two speed blower (override) switch then you have rear air conditioning. Also look in the overhead for the fan/temperature controls. Hope this will help.
May 14, 2010 | 1997 Dodge Caravan
Goodman heater not turning on
If your pressure switch is clogging then you need to check the flue pipe make sure it is not rusting. If it is the flue should be replaced and also think about replacing the pressure switch. Check your high limit switch also. If the pressure switch goes sometimes it pops the high limit
Feb 12, 2009 | Goodman GMS90703BXA Heater
Rinnai RHFE 1004F Error code 49
A 49 error code is caused by the pressure switch either not proving or a bad component. Check the hose attached from the plastic elbow located behind the heater going to a small square pressure switch found inside the heater. It may have come loose or a mouse may have taken a bite out of it. Also while you are behind the heater, pull off the hose that looks like a vacuum cleaner hose and run the heater with it unattached. If it runs, you have a blockage in the vent. If not, take a flashlight and go outside to the vent. Look down the center pipe for any obstructions. If it still does not work, you may need a new pressure switch.
While the front panel is off the heater, cycle the heater to attempt a start. You want to make sure the blower turns. If it does not, check the wire connections to it. You may be looking at a bad blower. If it is turning but still does not start, we are looking at a bad pressure switch.
Let me know what you find, I may have a switch or blower motor that you can purchase.
Oct 31, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
193 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
