I have a CP200 UHF RADIO.VOLUME IS ALWAY HIGH VOLUME I REPLACED VOL-POT ,PROBLEM IS STIL THERE.
Soldering around the area is ok but most likely there's an open circuit wih respect to the grounding of the volume pot Replace R507 with a 100 ohm resistor. It is a surface mount but if you don't have one use a regular 100 ohm and ground it to the pot terminal and to pin 3 of the switch (s444).
will work fine.
Posted on Feb 27, 2012
  • Bob Madsen
    Bob Madsen May 14, 2014
    How do you de-solder the pots ground leads without damaging the board?
Check and re solider the components around the volume pot. chances are that one is broken.
Posted on Dec 29, 2010
My Cp200 can't connect to my new Motorola Talkabout T5720 (7 Channels) 2-Way Radio, need HELP
The CP200 is a dealer programmable radio which was available in UHF or VHF. You would need the UHF model to match. Then the radio itself would need programmed to the same frequencies as the T5720. This requires Motorola proprietary software, cable and radio interface box (RIB). Your best option would be stopping by your nearest dealer to have it programmed.
Oct 21, 2015 | Motorola CP200 Two Way Radio
Volume
you have a bad volume pot do not try to replace it yourself.
Mar 31, 2014 | Motorola CP200 Two Way Radio
Cannot adjust volume
You possibly have a bad volume pot (potentiometer), or it is possible you are mixing narrowband and wideband radios together, and the narrowband radio is whispering to the wideband.
The volume pot is something which would be replaced during a radio repair. (Current 2014 pricing is around $85).
Best regards.
How can I program my rdu2080d to communicate with my cp200
Both radios require appropriate programming software and cables. Your CP200 would need to be a UHF model in order to match the CP200. Your best option would be visit your local dealer or contact an online repair center for help in programming.
Jan 30, 2014 | Motorola CP200 Two Way Radio
Is there a way to program the Motorola RDU4100 radio to the Motorola CP200 or visa versa to communicate on the same frequency?
If your CP200 is a UHF model the answer is yes. Both radios are dealer programmable to most frequencies between 450-470 MHz.
Best regards.
Aug 24, 2013 | Motorola Radio Communications
Motorola Radius CP200 flashing yellow when charged
The battery is no longer taking a charge properly and needs to be replaced.
Feb 12, 2013 | Motorola Mint Radius Cp200 Uhf 4ch Radio
ONE OF MY CP200 RADIOS HAS A STEADY SQUELCH SOUND ON ALL 4 CHANNELS, HOW CAN I FIX THIS?
One possible problem is a bad battery. Try swapping batteries with a known good unit and see if the problem is solved. If it is not the battery, then your radio is likely in need of repair.
Best regards.
Nov 09, 2012 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Compatibility
If your CP200 has a model number beginning with AAH50R it can be programmed to match the RDU2080d. If your CP200 model number begins with AAH50K, then the answer is no.
The letter R in the model number indicates it is UHF, and on the RDU2080d, the letter U in the model name indicates it is UHF. Both of these radios are programmable, and could be reprogrammed to match one another, if both UHF.
Best regards.
Sep 20, 2012 | Motorola CP200 Two Way Radio
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
Feb 29, 2012 | Motorola Radio Communications
Hi, i bought a Motorola CP200 radio and realised that it didnt work with my Motorola Talk-abouts! now i know that there is a programming that i need to operate with!!! so my question is....how can i know...
Take it too radio-shack and ask the salesman to try out a frequency meter to get the freq. you can get programming help by contacting motorola direct...1-800-638-5119
Aug 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
