Question about Broksonic SC20145 20 in. TV/VCR/DVD Combo
Remote control I need a new remote control for this tv-dvd-vcr player and iI don't have the old one so I don't know which one to order.
Get your model number and contact www.remotes.com
Posted on Oct 09, 2008
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
How to reprogram a universal remote control?
http://www.youtube.com/watch?v=fXDdeXmJjfM
http://www.remotecentral.com/features/remotes.htm
Instructions
    • 1 Find the brand of the universal remote you own on Internet sites like Remote.com (see Resources below).
    • 2 Click on your universal remote brand on the website to find the code list for that remote.
    • 3 Check to see if your remote is preprogrammed to operate your TV, VCR, or Cable Box using the following codes: TV - 000, VCR - 000, Cable Box - 000, AUX - use VCR code 037.
    • 4 Manually turn on your device. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
    • 5 Push the power button repeatedly until the device turns off, then hit "Enter."
    • 6 Press any other button while the device is on to see if the device responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps 4-6.
Read more: How to Reprogram a TV Remote ' eHow.com http://www.ehow.com/how_4454612_reprogram-tv-remote.html#ixzz1mji7B48P
Feb 17, 2012 | Sony DVD/VCR Combo Player
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
Need remote
You can call Insignia parts at this number: 1-888-237-8289. Give them the model number of you television and they should be able to help you. Hope this helps you with your problem.
Apr 22, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
I need a code for a sony remote for a maganasonic dvd player
You did not specify if is tv, dvd, vcr
try:
SONY DVD PAYER: 0533, 1533, 0864, 1033.
SONY DVD PLAYER/VCR COMBO: 0864.
SONY TV:0000, 1100, 0810
SONY TV/VCR COMBOS: 0000, 1232
MAGNASONIC TV/VCR COMBO: 1278
MAGNASONIC VCR:1278
SONY VCR: 0035, 0032, 0033, 0000, 1232, 0636
Jan 26, 2009 | One For All URC-4330 Remote Control
Coding to VCR and DVD
IF not then you should be able to program in Emerson 0591, 0675 for the DVD player
Emerson 0037, 0184, 0000, 0121, 0043, 0209 for the VCR
THe problem arises however, that the vcr and the dvd function buttons are the same, so you can only program one or the other. You need A different remote. I would suggest the 15-2142 made by radioshack. It is the Family 4 in 1 remote, and it has all the functions you need. THis remote is also backlit on some buttons to make it a little easier to see in the dark.
Mar 12, 2008 | Radio Shack (15-2147) Remote Control
I need the codes for a Magnavox dvd vcr player and a Orion tv.
I have a one for all remote, i have no codes for a coby dvd player.Can some one help with the codes?
Thank you, Don
Feb 18, 2008 | Televison & Video
MY DVD REMOTE CONTROL CODES
Its likely that the new new remote control has specific codes for the components it can operate. You should look to the remote manual or online source to find the code(s) for the DVD player you have. Without knowing the remote you purchased, its hard to locate codes for you.
Jan 26, 2008 | Thomson 24WK25U 24" TV
Need dvd code
Do you happen to know the model# of your Sylvania DVD/VCR player? That will help me access the correct codes for your set. Let me know, thanks!
Sep 24, 2007 | Philips PM3S Remote Control
Broksonic SC20145 20 in. TV/VCR/DVD Combo Logo
148 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
