Question about Canon EOS Rebel K2 35mm SLR Camera
Loading the canon EOS rebel K2 is impossible........
My camera is a newer camera bought in the last two years and i have used alot its my dads camera had he had it for a while and then gave to me but I can't get it load the little teeth won't grab and is annoying and it makes a horrible noise!! its stupid how do i get to work?
    Problem Solver:
  • 4 Answers
Look for slots on the takeup reel and stick the end of the film into one of those slots.
Posted on Oct 09, 2008
Need a copy of the canon rebel k2 manual
You may request a free copy of the manual here. You'll have to email the webmaster and specify the Canon Rebel 2K manual. The webmaster also requests a contribution, but that is optional.
May 20, 2012 | Canon EOS Rebel K2 35mm SLR Camera
I put new batterys in my canon rebel eos k2 but every time I take a picture the battery flashes.Why is this happening?
hello, maybe, you have the contacts of your lens or your camera with dust.
this make what the camera works wrong,
you have to clean the contacts of your camera an lens with a Rubber to erase, and the camera must be ok
Jul 09, 2011 | Canon EOS Rebel K2 35mm SLR Camera
I just purchased a Canon EOS Rebel K2 35 MM film camera body. What lenses are compatible with this camera?
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Jan 25, 2011 | Canon EOS Rebel K2 with 28-90 lens 35mm...
Camera indicator in back that shows how many pictures are left wont shut off and it drains the batteries because of this , it is a canon eos rebel k2 model, thanks for any help
That's entirely correct and normal, but the battery drain caused by the film counter is absolutely insignificant: think how long digital watch batteries last and they have far less power than your camera battery.
If the battery drains rapidly when the camera is not being used then there is something else causing the problem. Make sure that the camera is kept with a lens cap on when stored and not in use and consider removing the battery, although doing so for extended periods means that the camera will lose it's memory.
Jan 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
My canon eos rebel k2 will not turn on even with brand new batteries in it. What could be wrong?
Dirty contact in the battery compartment, bad power circuit, bad switch etc. Too many things to be able to fix in this forum. Send it in for service or buy another used one, that may cost a lot less than getting yours repaired.
Nov 22, 2009 | Canon EOS Rebel K2 35mm SLR Camera
I have a Canon ESO Rebel K2 camera and my low battery light comes
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Aug 10, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS Rebel S taking bad pictures
Your camera has a faulty shutter or shutter timer.
Given that you can buy a perfectly good Rebel S for anywhere between £1 to £25 on Ebay it's not economical to repair it.
Jul 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Nov 18, 2008 | Canon EOS Rebel K2 with 28-90 lens 35mm...
White balence
The EOS Rebel K2 is a film camera. White balance settings on digital cameras are an electronic 'adjustment' to the image sensor. In film cameras, the film is the image sensor. So white balance is dependent partially on the film you're using, but more often on the filters you add to the lens to correct for various lighting conditions and light sources.
Jun 13, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Canon eos rebel k2
That all depends on what you have your settings for. If you are not using the program mode, you'll need to make sure to check your Aperature and Shutter speed. Adjusting these might make your pictures come out better. Make sure to check your light meter, the needle or indicator should be in the middle for best results.
Jan 03, 2008 | Canon EOS Rebel K2 with 28-90 lens 35mm...
Canon EOS Rebel K2 35mm SLR Camera Logo
110 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
