Question about Dryers
Dryer Leaving Burn Marks On Clothes
I have a Figidaire stackable washer/dryer(gas)Recently I have had 2 problems with it.(1)A article of clothing will get caught on the inside while running and stop the dryer and leave a burn mark(2)Some clothing has burn marks when taken out of the dryer.
This is getting to be costly to my clothing budget and I am also afraid its going to start a fire.
  • Anonymous Apr 20, 2009
    I have had a shirt or two get stuck also and have a set of sheets with burn marks on them.
  • 943 Answers
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Posted on Oct 09, 2008
MY FRIGIDAIRE ELECTRIC DRYER IS LEAVING BURN MARKS ON CLOTHES,WHAT IS CAUSING PROBLEM
Assuming that you have the correct temperature selected for your clothes, there are two likely causes:
If the clothes are showing randomly shaped burn marks, the dryer is overheating. This would be accompanied by a burnt smell on the clothes. The high limit thermostat is the culprit.
If the burn marks are dark streaks, the clothes are getting pinched between the drum and the inside of the dryer that does not move. This is caused by worn bearings, slides or rollers. Should you choose to repair this yourself, there is a great deal on a kit with all of the parts you need plus a new belt for only $32 here:
http://www.repairclinic.com/PartDetail/Drum-Bearing-Felt-Seals-Pulley-Belt/5304461262/1261075
Good luck from Detroit, Mi.
Jul 20, 2011 | Frigidaire GLER341A Electric Dryer
Leaving burm marks on clothes
its getting to hot,,,check its air intakes to see if there blocked up and also the hot air outlets (hose pipe) if thats blocked up change it
Jul 10, 2010 | Hotpoint NBXR333EGWW Dryer
Dryer is leaving marks on my clothes. At least I think it's the dryer. It could be the washer. It's just leaving little gray lines, about an inch to an inch and a half long, in various places on my...
The dryer is prone upon leaving marks on clothes. The felt band surrounding the drum has worn out. Replacing this felt band will keep your clothes streak free again
Apr 28, 2010 | Washing Machines
Whirlpool Duet dryer - "burn marks", "out of round" drum
It's not really BURN marks - it is the adhesive used to affix the felt. You can substitute for silicone to remedy this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Electric dryer leaving brown marks on clothes
i would asssume that the marks are "crescent moon" in shape??? if so either the front or rear felt has/is going bad and casuing clothes to slip betweent the tub and the seal causing the streaks
Mar 14, 2009 | Whirlpool Dryers
Dryer is leaving burn marks on clothes on any temperature.
change your cycling thermostat. It is not telling your heat element to shut off at the rated emp
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Burn marks on clothes
problem is caused by drum seal usually the back one look closely at seal to see if there appears to be rust if so replacedrum seal ..clothes ten to rub against it while in motion causing brown streaks..would replace both front and rear just to be sure front doesn't give problems soon
Jul 26, 2008 | Whirlpool GEW9250 Electric Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
1,115 people viewed this question
Top Dryers Experts
