Question about Frigidaire Washing Machines
The washer wont complete a full cylce and then leaves water in the washer
  • 958 Answers
Check the lid switch. check if it has continuity if the lid is closed and open when you open the lid.
tnx 4 using fixya,
drcool
Posted on Oct 09, 2008
Cycle switch keeps tripping
Switch actuator (usually on washer lid) is probably broken if you can complete the cycle by depressing switch manually.
Jan 17, 2012 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool duet continues to fill with water
does the waste pipe go into a trap under the sink if so it can syphone from the sike back in to the machine
if not one of the water valves is sticking change it your self or get an expert to change
Jun 29, 2009 | Washing Machines
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Won't drain
check the water pump filter. located at the front of the water pump assembly. it could be clogged with dirt and small clothes such as socks and lint.
tnx 4 using fixya,
drcool
Oct 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
After washing cylce complete; 3-4 inches of water is left
it sounds as tho water is getting intyo machine after use. there are 2 possible causes.
either
inlet valve leaking. turn water off and see if this stops water accumulating. if it does, then you need to replace valve to cure.
or
if drain is plumbed into spigot on sink trap then every time you drain sink, some of the water goes down the drain hose.
to cure, take the drain hose up as high as possible in a swan neck
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
did you try running a drain and spin cylce? there might be water in machine still and thats why door not unlocking..Assuming theres no water in machine( youcant see any waterline though glass) you can remove the bottom cover (3 torx 15 screws) UNPLUG UNIT. reach your hand up approx six in. on right inside face of unityoull find a manual release for the door lock assy, round tab mounted to bottom of latch assy approx size of a quarter, give it a pull and door will open,might be a fluke that it lock but i would check for operation before filling with close again
Feb 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Basket wont spin, still agitates and drains...
  1. Check the carbon brushes on the motor. they are probably worn and easily replaced..
Nov 27, 2007 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
