Question about Panasonic KXTG2344 Cordless Phone
How to reset a kxtg2831
Ive a problem with the hanset, i cant register in the base, witch is the pass to hard reset the hanset
  • 12 Answers
SOURCE: expandable handset will not register
It sounds like the base unit has other handsets registered to it. This is why you are getting the message "All Handsets Registered". You will need to reset the base unit in order to register your two handsets.
Hopefully this will help you. Put the phone in an easily accessible spot where you can plug it in and unplug it easily. Unplug the phone, wait a few seconds, and plug it in again. Now, unplug it again, and before you plug it in once more, hold down the Locator button as you plug it in and all lights should flash on. It should emit a long beep, which means it has reset. If not, you will need to unplug it once more and hold down the Locator button again as you plug it in.
Once it beeps, it should allow you to add your handsets. If there is nothing on the handset display, press the off button, menu, then 001. It should then read "Press LOCATOR on base for 3 sec, Then press ok". At this point, you will need to hold down the Locator button until it flashes before hitting okay. The handset will be registered when it reads "Handset 1 Registered".
If this doesn't work, I would call Panasonic.
Good Luck!
~Julia
Posted on Jul 22, 2009
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
How do i reset the BT XD 1500 as had to replace hanset and can not get to work with the base?
uk-surplus.com/manuals/freestyle2200.pdf - United Kingdom
user guide above. please download
Please follow the instructions in the manual and no doubt you will get it all working again.
You most likely simply need to reset and re-register it with the Base.
Aug 12, 2010 | British Telecom Freestyle 2200 Trio...
How to register phones?
Reset Procedure for Cordless Phones
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Mar 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Expandable handset will not register
Good Luck!
~Julia
Jun 04, 2009 | Panasonic KX-TG6071M Cordless Phone
No dial tone
Have you replaced the phone cord to the wall? if not start here, if the base has not been dropped or wet, try resetting it.
Question:
What is the general reset procedure for cordless phones?
Answer:
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
Hope this is of some help.
Ed
May 05, 2009 | Lands Phones
Uniden base display does not work after chargin for 1st time.
Question:
Answer:
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
Hit the deregistration button. phone will not work now.
Question:
Answer:
May 05, 2009 | Uniden Cordless Phone
7805 model
please rate this post!!
Aug 24, 2008 | Uniden 5.8GHz Dual Cordless Phone
Tesco arc200
I solved it out u must pres de paging button on the base while registering the phone to base keep the paging button pressed until starts to beep like 5-10 sec. Good Luck
May 16, 2008 | Uniden Cordless Phone
Panasonic KXTG2344 Cordless Phone Logo
42 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
