When i plug in my toshiba hard drive the light flashes on and of and the computer does not recognise it
    Master:
  • 538 Answers
Plug it in while the system is running...hmmm..not a hot swappable...you will need to use F2 to get to bios setup and then see if the bios can see it first
Posted on Oct 09, 2008
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
My toshiba external hard drive is not being recognised
This problem occurs when the external drive is removed from the computer before the host computer has finished writing to the drive. This can cause the drive to fail and require formatting. When using a plug in drive you need to allow the system write to complete before removing it. This goes for Flash memory sticks/cards and hard drives.Try restarting the computer with the external drive plugged in and switched on, this may cause the fault to be fixed. Good luck.
Aug 07, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
My Toshiba px1394u-3g50 external hard drive is not working, light flashing and not recognised
Try connecting the hard drive to some other laptop and see if its getting recognized. Issue could be either with the hard drive itself of it could be with the usb port which you are using to connect the hard drive to your laptop.
Jan 17, 2012 | Computers & Internet
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
To start with My 'Sandisk Cruzer micro 8gb' USB flashdrive has failed. Nothing has happened to it, like getting wet or anything, but when I plug it into the computer the orange light (the light that it...
well the flash might be corrupted if u have pluged it recently on some mp3 player like those in the care that work on the radio signal, the electricity circulation in those mashines can broke ur flash drive.
if u want to make sure it is broken, u should go to administrative tools, and choose device managment, then disk managmen, if its note there, then its a 90% broken flash drive.
Apr 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Lacie 500Gb Hard Drive Porsche design
Hallo,
my disk, when on, is not recognised by Windows while the light is flashing between yellow and orange fast (like a car's flash -faster-). please could anyone help me? - i need my data!
Thank you.
Aug 21, 2008 | LaCie 500GB FireWire-400 Porsche - 7.2K...
Lights on but no one at home
you'll need to add it in my computer, as a logical external drive...
and when plugging into usb, recommend plugging in when it's powered down, not when it's active.
Apr 20, 2008 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
