Question about Sharp AL-1642CS Copier
Wont print keep getting that ziggy line error loke paper jamemed but it is not.. the drum ..i can hear it going rouns and round like it wants to print..but it don't...any ideas
  • Gavin Andrew Essex
    Gavin Andrew Essex May 11, 2010
    Hi Robinsonwill,
    Please clarify which error you keep getting.
    If it is a red lamp that comes on, on the operation panel, what does it look like?
    • a Figure 8 with a lightling strike next to it - this indicates that there is a paper misfeed in the machine. Check that the paper is loaded correctly in the paper tray and that the side and end guides (normally green plastic) are right up against the paper edges so as to hold it in position, when replacing the paper tray always push the paper down until the tray-flap clicks, there is a spring under the flap on the right hand side of the tray and the paper should be lying flat when you close the tray so that the paper does not move and feed scew.
    • if it is a red dotted triangle then the machine needs new toner and will just keep on turning inside whilst it is trying to add toner to attain the right concentration ratio.
    Hope this helps you
    Regards
    Gavin
  • Sharp Expert
  • 257 Answers
Clean paper pickup rollers with clean soft cloth dampened with water or alcohol.
Posted on Oct 05, 2009
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
Scuff/score lines down print plus central grip mark
Possibile solutions
1) Complete cleaning using copressed air or lint free cloth
2) check the cleaning blade on your drum (Round Glass cylinder)3) Change your drum unit
4) replace rollers
Oct 10, 2013 | Canon Pixma Ix6550 A3 Inkjet Printer
I tried printing and didnt realize i had papers sitting on top of printer it printed and crumbled papers as it was printing now i have it blinking error , i check for paper jam , its all clear i cant get...
    See below. It's the steps after 7 that is most likely part of you issue. Refer to your user guide (or see below for a link to an online version) for illustrations.
  1. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  2. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  3. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  4. Close the front cover.
    Note: Do not put the drum unit and toner cartridge assembly back in at this point.
  5. Pull the paper tray completely out of the printer.
  6. Pull the jammed paper down and out of the printer.
  7. Open the back cover (back output tray).
  8. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  9. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
    After you have just used the printer, some internal parts of the printer will be extremely hot. Wait for the printer to cool down before you touch the internal parts of the printer.
  10. Close the back cover (back output tray).
  11. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
    Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    To avoid print quality problems, DO NOT touch the roller part of the toner. Try to keep you hands, fingers and everything else away from there.
  12. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  13. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  14. Put the paper tray firmly back in the printer.
  15. Close the front cover.
  16. Make sure that the Error LED is now off.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Jan 29, 2011 | Brother HL-2170W Laser Printer
DRUM ERROR - HAD PAPER JAM, CLEARED THAT AND NOW IT WILL NOT PRINT - KEEP GETTING DRUM & ERROR
Sorry to hear you are having problems. Printers can be very frustrating at times. Below is a description of how to complete clear paper jams paper can get jammed it there pretty tightly and in very small places. Ensure you've followed all the steps to clear your paper jam and you should see your printer start working again. Refer to your user guide (or download via the link provided at the bottom) for illustrations.
  1. Open the front of the printer.
  2. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  3. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  4. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  6. Pull the paper tray completely out of the printer.
  7. Pull the jammed paper down and out of the printer.
  8. Open the back cover (back output tray).
  9. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  10. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
  11. Close the back cover (back output tray).
  12. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
  13. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  14. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  15. Put the paper tray firmly back in the printer.
  16. Close the front cover.
  17. Make sure that the Error LED is now off.
Jan 27, 2011 | Brother HL-2170W Laser Printer
Brother Laser Printer, paper gets stuck and printing wipes off.
Opened up the back and found there is a plastic cog wheel on the end of an orange drum, which must be the Fuser Unit, which was damaged. So the paper was getting as far as the drum but the rollers to pull it through the Fuser Unit were not going round. A new Fuser Unit seems to be about £99 plus VAT and I don't supose a new printer is much more than that. So if anyone has a spare Fuser Unit for a Brother HL 5140 which is still in good working order I would be happy to consider buying it. Alternatively I have 2 x spare drums DR3000 and 1 x toner TN3060 for sale !!
Oct 25, 2009 | Brother HL 1440 Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
