Question about Toastmaster TM1046U Global Design Toaster
I want to know what the retractable metal pongs are for?
Is ther a manual for this toaster. It was given to me. It works good so far.
How to remove the cover on an oster toaster TSSTRTS2S2-033
re: Oster TSSTRTS2S2-033 disassembly
Hi, I just took one apart to fix a cold solder joint, so here's my take on disassembly.
The brushed aluminum cover comes off by removing nine screws on the bottom, then manipulating seven tabs and removing the main handle on the plunger.
First, remove the main handle. It has a small plastic locking tab underneath and the tab may break because it hooks onto a metal spike in the toaster and this seems intended to be permanent. I broke it because I just pulled the handle straight off, but I'm not worried because the handle will still go back on reasonably tight; it just won't lock. However, if you want to try to remove it without breaking the plastic locking tab, I would try sticking a thin screwdriver under the bottom of the handle to disengage the plastic tab from the spike.
Next, remove nine of eleven screws on the bottom. Don't remove the two screws directly below the cord switch on the side - it should be obvious which two screws stay on. And take the crumb tray out too.
Next, there are three metal tabs on the bottom that need to be bent. Two of the tabs were held by the removed screws at the back of the toaster. Just bend those two out of the way away from the plastic bottom. The third tab is located in a hole directly between those other two tabs. Take a pair of needle nose pliers and twist the tab so it will unlock and allow the tab to slide through the slot in the plastic toaster bottom.
The four remaining tabs are located on the top of the toaster just inside the main toast slots. The top metal cover folds into the toast slots and forms metal tabs at each end of each toast slot. They unhook relatively easily by sliding the top cover tabs about 1mm towards the centre of the toaster - there's no bending of metal required.
At that point, it takes some playing around to actually remove the cover. Start by working it straight upwards, then lift it off at the back of the toaster first, before the front because there's a cable at the front of the toaster that prevents the top cover from lifting completely off straight up and, as well, the metal plunger arm that holds the handle will be the last thing to unhook. The plunger arm and the cord retraction mechanisms do get in the way, but it is possible to do it without forcing anything.
Note that after the metal cover is unfastened and pulled off, it is still attached to the toaster mechanism by a short internal electronics cable which connects the toaster to the front buttons in the cover. The front buttons and display remain attached inside the cover. At this point, the toaster should still function normally despite it having the cover off.
I hope that helps.
JimmyHaulinHogs
Sep 02, 2013 | Oster Toaster Ovens
Pulled out the Holman hose out too far..now won't retract at all...hubby is going to kill me!
yeh i pulled mine out too far now wife wants to kill me!!
anyway opened it up and spring was broken!!
Apr 13, 2013 | Kitchen Appliances - Others
Manual/instructions
the manual can be found here...
http://www.hamiltonbeach.com/use-and-care/use-and-care.php
Enter "Toaster Ovens"
and, then "31197"
you will be able to download the manual here...
Jun 30, 2010 | Hamilton Beach 31197 120 Watts Toaster...
Help with toaster. anyone there?
Well, I'm not a toaster pro, but I do make my fair share of toast.... I have an idea for you, I researched your product and couldn't find any specific help but try this:
Unplug your toaster, firmly hold the mechanism in the down position as far down as it will go, then turn the unit upside down, give it a good shake and flip the lever a bit. Reinvert, plug it in and see if you've got any improvement. (I think I learned this trick from the Andy Griffith show... you know old Emmett and the fix it shop) let me know if it worked! Sorry I can't be more help.
Dec 12, 2009 | Rowenta TL900015 2-Slice Toaster
Manual for turbo-oven
I have this manual. I have been using this oven for almost 30 years. (I love it!) However, I'm having trouble with internet connections at the moment. As soon as I can get a good connection again, I will scan the manual and upload it here for those of you who need it.
Sep 06, 2009 | Farberware T490C 1500 Watts Toaster Oven...
Front Brake Pads locked up on Rotor
Have the brake pads been so very work they are down to the metal? This could cause the caliper piston to extend too far and not be able to retract properly.
Calipers Fail mostly from a cut in the rubber boot around the pistion dirt and debris get in there and rust the piston and it cannot retract properly Do they retract after they cool Down? if so the brake fluid has "boiled" if brake fluid is not changed about every 24,000 miles condensation builds up and lowers the boiling point of the brake fluid causing this problem.
Tell me does it happen after a long drive or siting a long time in heavy bumper to bumper traffic in hot summer weather? I recommend a complete brake fluid flush an change the calipers with NEW ones ot rebuilt and use dielectric grease on all points of metal to metal contact between the caliper an the mount bracket and thee ends of thee pada n the slide points they ride on and the pins that go through thecaliper and thread into the mount only dielectric not regular grease it will cause sticking and a worse problem than you have now.
Aug 25, 2008 | 2001 Dodge Caravan
Toastmaster TM1046U Global Design Toaster Logo
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
