Peavey banit 65 guitar amp. When turned on it makes a loud almost feedback sound with out anything pluged into it.
    Scholar:
  • 142 Answers
A few things can cause it. Bad ground\bad power supply filter capacitor\bad low level op amp IC. You most likely have a bad power supply or trouble at your input jack. Good luck!
barneyluc
Posted on Oct 10, 2008
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
Peavey solo series SPECIAL 112 ; Loud him , intermittently
Most of the time amplifier hum is caused by the outlet that it's plugged into, maybe no ground or there's other appliances on the same circuit causing interference? And sometimes it's as simple as a little internal feedback, certain C notes on the Guitar cause distortion with tube amps, the best fix is a $100 power conditioner like made by Monster cables or others.... hope this helps?
Feb 27, 2015 | Peavey Music
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
Action is a bit high. Everyone is saying the DC16RGTE guitar sounds great and gives good volume. I found the one I have is not loud and it has too much boom. Is there a problem with this guitar?
Make sure the guitar CANNOT "HEAR" the amp you are using. Local regeneration (feedback below the level to sustain full feedback) will give a boom sound like in a cave. If you get near enough to the amp for feedback to build up, you can actually see the string vibrating and building up. The loudness has much to do with the amp you connect this too and the settings
Aug 30, 2011 | CF Martin DC16RGTE Aura Drednought Cutaway...
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
My amp and cable are working... but my guitar wont make sound... when i turn up the amp it makes white noise... HELP!!!
PLUG YOUR LEAD INTO AMP TURN UP JUST A LITTLE SEE IF IT BUZZES WHEN YOU TOUCH THE END OF YOUR CABLE.IF IT BUZZES THEN THE FAULT IS IN YOUR GUITAR MOST LIKELY THE ACTIVE WIRE HAS COME OFF THE INTERNAL GUITAR PLUG.
Nov 04, 2009 | Peavey Music
Hi- When I plug in my les paul into my new peavey windsor class A amp, I get a loud hummimg noise. But when I mute the fretboard or touch anything metal on the guitar, it goes away. I don't have this...
Sounds Like The Amp Has A Grounding Problem Check To See If The Ground Wire Is Hooked Up Inside The Amp And Or If The Pin Has Been Broken Off The End Of The Cord.
Sincerely,
Michael Scott
Jul 24, 2009 | Music
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
70 people viewed this question
 Grubhead
Grubhead
