Question about Epson Stylus Photo R2400 InkJet Printer
Print head alignment +won't feed paper
My printer is notproperly aligned, I can run thro the printhead alignment facility & correct it, but when I switch off & go to use it at a later date, I have the same problem. Also the paper won,t feed unless I do a manual feed with the paper button.
  • 282 Answers
Best solution is to clean the head with it in place,here's
the manual for your printer
Posted on Oct 09, 2008
Tip
Cleaning out a printer
Canon Printer Tips
Unclogging The Printhead - Three Methods
Canon printers have a semi-permanent printhead. It's the 'holder' that the ink cartridges (tanks) fit into. It can be removed fairly easily. Over time, it can and does become clogged, mainly from letting the printer set without use. You need to print both black and color at least once per week in order to prevent clogging and keep the ink flowing.
Normally you can clear up minor clogs and streaking by running the cleaning cycle found in your printer's software utility. For quick access to your printer's utility (drivers): In your browser's address bar type: control panel\printers and hit 'enter' on your keyboard. This will bring up a page with your installed printer's icon. Place your mouse cursor over the printer icon and 'right-click' on it. When the dropdown menu shows, click on 'properties'. This will bring up the printer utility. Look for the 'maintenance' tab and follow the cleaning prompts.
If the cleaning cycles don't do the trick in clearing up poor and incomplete output, don't give up and assume you'll need to buy a new print head (they often cost more than a new printer!). You can try the following as it will cause no harm: (we and many others have succesfully done this)
Remove the ink tanks from the printhead (tank holder) and seal them in a ziplock plactic bag. Set them aside, preferrably propped upright. Next remove the print head, it snaps out. Use the kitchen or other sink and turn the water on so that it is running slowly and that it is warm. Hold the print head, bottom facing down, and cup your hand under the running water so that the water fills it up and flows into the the print head. This will flush the ink out of the printhead. You'll need to turn the print head over, bottom side up, and flush it that way as well. You'll see when there is no more ink being flushed out.
You WILL need to do a final flush/rinse with some distilled, or purified water. This ensures that any risidual minerals or impurities of the tap water are flushed out of the print head. Set the print head on a paper towel to dry, drying time will vary. TIP: To expedite the drying process, shake the printhead vigorously as there is a fair amount of water retained after rinsing!
Place the printhead (tank holder) back in the printer and reinsert the inks tanks. The printer should automatically do a print head alignment. If it doesn't, manually perform a "Printhead Alignment" through the printer's utility. Next, run the "printhead cleaning" cycle and print a nozzle check.
Here's another, similar method:
Open the lid of the printer and when the print head moves to the left, remove the cartridges (tanks). You should then be able to easily remove the print head. It has the circuitry on it and on the bottom are the outlet nozzles.
Get a small, shallow pan and lay a couple of paper towels in the bottom. Heat up (via microwave) enough purified/bottled water to cover the paper towels. Set the print head on the towels. You should see ink 'bleeding' out. Move the print head to several different spots (about a minute each spot). This will dissolve the ink clogs. Remove the print head and gently dab it dry on fresh paper towels.
Place the print head back in the printer and insert the ink tanks.Run a print head alignment and a regular cleaning followed by nozzle check and test print(s). That should do it. If not, repeat the above procedure(s).
If the above two methods don't quite do the trick, try this:
Remove the ink tanks and printhead (cartridge holder) from the printer as instructed above. Get a small bowl, dish or pan, large enough to accommodate the printhead. Lay down a layer or two of paper towels in the bottom of the container to protect the printhead circuitry from contact damage.
Make up a 50/50 mixture of ammonia and distilled water, about a pint will do. Heat the mixture up in the microwave for about a minute or so, not boiling. Slowly pour over the paper towels so that you have approximately 1/2 inch mixture total. Set the printhead (cartridge holder) into the container and pour some of the remaining mixture over the top, just enough to wet it good. Let it soak for several hours (3-4) or overnight. You can move it slightly to a different spot every hour or so.
Remove the printhead and rinse thoroughly with distilled water. Shake it dry, set it on folded paper towels to air dry. Reinsert the printhead and ink tanks. The printer should do an automatic "Printhead Alignment", if not manually do so and run a cleaning cycle or two followed by printing a nozzle check pattern to check your progress. Repeat as necessary.
" cycle and print a nozzle check. Here's another, similar method:
on Jul 21, 2010 | Office Equipment & Supplies
After a paper jam on my Canon Pixma MP540, the printer still prints but the alignment is very poor. I have uninstalled and reinstalled the printer, and have used the print head alignment facility within...
If you are comfortable in tearing down the printer and putting it back, This should help you identify the problem. There is something that went out of alignment when you took off the paper that got jammed. Check the paper feed assembly, rollers and the stabilizer bar. If you don't know any of these things, I suggest you consult a local technician to check these parts for you.
Hope this work for you.
Jul 23, 2011 | Canon PIXMA MP540 All-In-One InkJet...
The orange light keeps flashing
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 22, 2010 | Canon I990 InkJet Photo Printer
I am getting an error message of 08.055.44:9347. Every time we go to print the page is blank.
8,055.44: The Media Drive stalled while engaging headtilt.
Troubleshooting Procedure for Wiper/Media Gearbox
Step Questions and Actions Yes No
Check for obstructions in the Wiper
Assembly path.
Is the Wiper Assembly obstructed by the
Printhead or wiring?
Clear any
obstructions.
Go to Step 2.
2 For an 8,005.48 error:
1. Check for paper in the paper path that is
adding drag to the rollers. Look for paper
or wiring interfering with the take away
roller.
2. Remove the Tray 1 Pick Solenoid to view
the meshing of the Take Away Roller’s
gears to the Media Drive Assembly.
Did this correct the problem?
Complete. Go to Step 5.
3 For an 8,007.41 error:
Check for a missing KL-clip securing the
Head Maintenance Clutch. Replace if
missing.
4 For an 8,009.43 error:
1. Ensure that there is no paper in the paper
path adding drag to the rollers.
2. Ensure the Media Drive Assembly is fully
seated and correctly installed.
3. Remove the Tray 1 Pick Solenoid to view
the meshing of the take away roller’s
4. Ensure the feed rollers are properly
engaged in the drive gears.
Complete. Replace the
Media Drive
Assembly.
5 Run the Wiper Drive test.
Did the test pass?
Go to Step 6. Go to Step 7.
6 Run the Wiper Alignment test (see “Wiper
Alignment Procedure” on page 6-2).
Did the test pass?
Go to Step 8. Go to Step 7.
7 1. Inspect the wiper system for improper
operation, obstructions, or damage
(broken gear or belt). Look for ink in the
Wiper Belt channels.
2. Ensure the wiper system is properly
aligned (see “Wiper Alignment
Complete. Go to Step 8.
8 Run the Head Maintenance Clutch test.
Did the test pass?
Go to Step 9. Replace the
Head
Maintenance
Clutch.
9 Is the head lock mechanism on the right end
of the Exit Module functioning properly?
Go to Step 10. Replace the
Exit Module.
10 Are there obstructions or spilled ink on the
Wiper Blade, the Head Tilt Gear drive path,
or under the Printhead?
Is the Waste Tray overfilled?
Clean the
inside of the
printer and
retest.
Jul 31, 2009 | Xerox Phaser 8400 Laser Printer
My canon i350 suddenly prints mostly in pink and black.
Go to Control Panel and double click on Printers. Place your mouse cursor over the printer icon and 'right-click' on it. When the dropdown menu shows, click on 'properties'. This will bring up the printer utility. Look for the 'maintenance' tab and follow the cleaning prompts. If you look in the printer's utility menu, you can do a Printhead Alignment, and then a Printhead Clean.
Canon Printer Tips
Hope this helps
Chris (ziraffa)
Jan 07, 2009 | Canon i350 InkJet Printer
Printhead problem (black/yellow) on HP L7780
When you removed the paper it's possible your damaged it and that's why the message is not going away. Did you try to put the cartridge back in to make sure it had not come out of position and just remove the power cord for a minute then plugging it back it.
Here are the steps to make sure you properly change the cartridges and the heads...
Install the ink cartridges and printheads Step one: Install the ink cartridges All four ink cartridges must be correctly installed for the HP All-in-One to work. Follow the steps below to Install cartridges:
  1. Open the ink cartridge cover.
  2. Remove each ink cartridge from its package.
  3. Align each ink cartridge with its color-coded slot and then insert the ink cartridge into the slot. To ensure proper contact, press down firmly on the cartridges until they snap into place.
  4. Close the ink cartridge cover.
Figure 1: Installing cartridges c00841893.gif 1 - Open the ink cartridge cover. 2 - Remove the ink cartridges from the packages. 3 - Install the ink cartridges. 4 - Close the ink cartridge cover. Step two: Install the printheads Follow the steps below to install the printheads.
  1. Open the top cover of the printer. Figure 2: Open the top cover c00848391.gif
  2. If the carriage does not move to the left automatically, press and hold the Resume button (c00847980.gif ) for three seconds. Wait for the carriage to stop moving.
  3. Remove the cardboard cover from the printhead carriage. Figure 3: Remove the cardboard cover c00848392.gif
  4. Lift the printhead latch. Figure 4: Lift the printhead latch c00848393.gif
  5. Before installing a printhead, shake the printhead up and down at least six times while the printhead is still in its packaging. Figure 5: Shake the printhead while it is still in its packaging c00847983.gif
  6. Remove the new printhead from its package, and then remove its orange protective caps. CAUTION: Do not shake printheads after the caps are removed. Figure 6: Remove the printhead from its packaging, then remove the orange caps from the printhead c00847984.gif
  7. Insert the printhead into its color-coded slot. The label on the printhead must match the label on the printhead latch. Press down firmly on the printhead to ensure proper contact. Figure 7: Insert the printheads in the correct color-coded slots c00847985.gif
  8. Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch. Figure 8: Close the latch c00848394.gif
  9. Close the top cover. Figure 9: Close the top cover c00847987.gif
Step three: Align the print heads Whenever you insert or replace a printhead, the printer automatically aligns the printheads to ensure the best print quality. If the printer does not print the alignment page automatically, start the alignment process manually. To start the alignment process manually:
  1. Press the Setup button on the control panel Setup and the number 6 on the keypad or scroll to Tools .
  2. Press 4 on the keypad or scroll to Align Printer . The alignment process starts.
Dec 01, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
If reprinting did not help, try increasing the print quality mode.
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Step four: Clean the printheads
If the print quality is still bad, clean the printheads.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Step five: Align the printheads
If the print quality is still bad, align the printheads.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed
If the print quality is still bad, calibrate the linefeed:
Open the printer Toolbox and select the Printer Services tab.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads
If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
Press the Setup button.
Press 1 and * simultaneously.
Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
If the Black block has lines – replace the KY printhead.
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
If the Red block has lines – replace the KY printhead.
If the Green block has lines – replace the KY printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Will it mess up my printer if i pulled the paper out
No. But, do this while the power is off. And get a firm grip on the center of the paper and pull with increasing constant pressure until the paper come out. You don't want to risk tearing the paper. Should that happen, open the cover and see if you can't pull it out backwards. In fact, if there is more paper stickng out the top than the front, pull it out from that direction.
After you get the paper out, remove the paper from the feed tray. Turn the printer on and let it go through its startup diagnostic (that's what all the commotion and noise is about when you turn it on.) Once complete, add some paper to the tray and from either the LCD Panel menu options, run the print head alignment test and set the values according to what lines line up exactly and punch those numbers in. The print head alignment test may also be available to you from the printer's program menu tools or from the Start Menu, Printers and when your printer shows up in the box, right click your printer, choose Properties and there may be a set of tools from there that will run the print head alignment test.
That's the long and short of it, Yes, pull it out from above, from the feed tray or from the front, whichever has the most paper exposed. Then run the print head alignment test to reset the alignment.
Regards,
Worldvet
Jul 10, 2008 | HP Computers & Internet
Brother HL 2040
Make sure the paper aligning slides are tight to the sides of the paper. In the case that they are spring loaded make sure there is not something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears crooked it is related to the print head assembly. If the text is not aligning to the edge of the page then the paper is not feeding straight and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping the paper and it is forcing it to one side as it pulls it in.
Mar 10, 2008 | Brother HL-2040 Laser Printer
Epson Stylus Photo R2400 InkJet Printer Logo
384 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
