Question about IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3500
Can turn typewriter on but the wheelwriter will barely move when hitting the space key and makes a skipping sound. It sounds as if it the wheelwriter is lodged. Sometimes code 215 with a small block will appear. I used the typewriter yesterday and everything seemed to be find but when I came in this morning the typewriter was doing the above.
  • IBM Master
  • 3,594 Answers
First look inside the typewriter for forgien objects and debris, Then put some libhe oil (WD40 works well) on the shaft that the print head slides on.
DickyO
Posted on Oct 09, 2008
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
When I type, the keys move but they do not stike the ink ribbon.
You probably have a broken solenoid cap. You will need to order the cap but I do not know who has a video or instructions to do it.
Apr 08, 2014 | IBM Wheelwriter 3500 By Lexmark Electric...
How do I re-set the right margin for a IBM Wheelwriter 3500 Lexmark?
Go to the R. margin, press and release mar rel key, space to desired location press R. mar key.
DickyO
Mar 16, 2011 | Lexmark Wheelwriter 3500 Typewriter
How do I turn off the chirping sound on my IBM
If you hold down the "code" key and press the "S" key it will turn off the chirp.
Jun 03, 2010 | Lexmark Wheelwriter 3500 Typewriter
IBM WHEELWRITER 5
You probably have the right margin set to close yo the lrft and have auto return on. To turn off auto ret. hold the code key and touch "R". To move the margin tab to the rt. side and touch rt. mar. key.
DickyO
Jun 30, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3500 only printing top half of letters
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
DickyO
Mar 20, 2008 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 6
The print solenoid has the plastic cap on the end broken or desintagrated. i fix this all the time. also make sure you didnt turn on the lang feature. that will keep your carrier in one spot for certain foreign symbols. to clear it hold down the features key next to the space bar and hit the lang key with the features key depressed. Lawrence
Feb 11, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 1000 - How to clear all tabs
Using the space bar move the carrier (print head) all the way to the right, press and hold tab clear key and hit the return key.
Dec 14, 2007 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 3500
Press and hold thr code while hitting the RELOC key on the rt. side of the keyboard the lower rt. hand corner of the display will change to indicate spacing.
Nov 05, 2007 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
136 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
