Question about Epson Stylus Photo R200 InkJet Printer
Epson R230 blinking 2 red lights after cleaning clog
I manually cleaned my clogged head by a syringe .... after which it gives me 2 red lights..... i dont know wht has gone wrong ... it never gave me this prob before .....
  • 2 more comments
  • Anonymous Mar 07, 2009
    I have this problem Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on.
  • Anonymous Mar 16, 2009
    R200 printed perfectly before changing yellow cartridge. Now red lights blink alternately and the green light is out. And I know there is no obstruction and the print head can move freely.
    What causes the blinking????
  • Anonymous Apr 06, 2009
    there is a foreign object inside the printer, printer job delay
  • jh_6905 Apr 10, 2009
    I have same problem, after I change my cartridge (all of it) my printer blinking 2 red lamp. how I must suppose to do, please anybody, help me...
Look for a tool called sscserv. but you still have to clean wastepad, so it's a good idea to have external tank.
Posted on Dec 17, 2008
Posted on Sep 14, 2010
Help!!!
Posted on May 21, 2009
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
My test indicated that I needed to clean the print heads. After 6 cleanings, all is ok, except the Magenta pattern is about 1/3 complete with gaps. The ink is about 1/2 full, and all other colors are...
Hi Mr. walter
This is a problem of clogging of head. You need to un-clog the head hence you need to have with you the following
1. A syringe any capacity
2. Hot water
DO NOT USE ANY OTHER GLASS CLEANING LIQUIDS
1. First take the carriage cradle out of the capping station.
2. Take the hot water in the Syringe and slowly pump a little qty. of water in the Magenta inlet nozzle
3. Then pull the syringe back so it will get the water from inside out in the syringe.
4. Inspect if any small derbies of clogged ink is being sucked by the syringe.
5. Now again pump a little hot water into the ink inlet nozzle
6. Repeat Step 2 again for 3 more times
DO NOT PUMP THE HOT WATER WITH A GREAT FORCE THIS WILL DAMAGE THE HEAD.
Jul 16, 2011 | Epson Stylus 2200 InkJet Photo Printer
The printer turn on ok , then whene i print any thing the printer work ok but its not printing on the paper .
It seems like its a jammed print head for this try cleaning your print head using the cleaning utility thats present in your printer software, (NOTE: Head cleaning will consume a lot of ink) Or you can just clean your head with isopropryl alcohol.
Requirements:- 1. Isopropryl alcohol 2. Syringe 10 or 20ml 3. Tube(I used medical tube) that fits in the tip of the syringe and the nozzle
Steps: 1. First remove the needle from the syringe and fit the tube into the tip till its firm. 2. Pull 10 ml of isopropryl alcohol inside the syringe (note: no vacuum or air should remain inside the syringe) 3. Fit the tip of the tube on the nozzle of the print head and slowly squirt about 5ml of isopropryl into the nozzle and pull back till all the isopropryl comes back while pulling back clogged inks will come inside the syringe repeat this till the nozzle is clear. repeat this to all the nozzles. don't forget to throw away all the dirts (clogged inks that will come inside the syringe) and do it slowly, though it will take much time but it will be helpful. I was able to clear my jammed print head with this procedure hope this will help you.
Apr 17, 2011 | Epson STYLUS R230 InkJet Photo Printer
My Epson Stylus R230 has both red lights blinking alternately
Your printer has reach its maximum count of cleaning and printing. This need to be reset using epson adjustment program. But before resetting make sure that you have replace the waste pad inside your printer or it is much better to point outside the hose where the waste ink goes out.
Jan 21, 2010 | Epson STYLUS R230 InkJet Photo Printer
My Epson Stylus R230 has both red lights blinking alternately do you know how i can fix this please??
You need to reset waste ink counter. Use SSC Utility or R230 Adjusment program. Find at indoreset.blogspot.com. Don't forget to replace waste ink pad, or just extend outlet pipe of head cleaning mech to outside bottle.
Aug 28, 2009 | Epson Stylus Photo R200 InkJet Printer
I have 2 Epson R230. One has a bad printhead, in that the test print is messy and the black print head is badly clogged. I want to swap the printheads, so that I will at least have one working printer. The...
Befory you toss the printer, try this!
Take a syringe, 1" piece of rubber tubbing that will fit over the head input snugly, (auto parts house stocks some that works fine). Fill the syringe with a good head cleaner, slightly warm it in the microwave (try 5 seconds to start). Attach to nozzle, gently pull back just a bit, then apply a little pressure. If it accepts the fluid, STOP, You can clean the syringe, add the proper color ink, inject just a small amount. reinstall a known good cartridge, clean heads couple times checking results, if ANY streaks or color appears, clean again! Sometimes letting it sit overnight allows the head to fill with ink. I have had very good luck with this method, also some will not clean properly, just depends on how bad it is clogged.
Good luck..
May 18, 2009 | Epson STYLUS R230 InkJet Photo Printer
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Mar 10, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Sep 29, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus R230
sir, my printer Epson Stylish Photo R230, printer colour and paper lights continues flashing please solve the problem
Jan 30, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
6,212 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
