Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
Inserting SanDisk Cruzer in USB, REBOOTS the Computer instantly
Computer PC, Widows XP Pro SP3, 6 USB, 4 used by Scanner HP,MS Mouse,Web Camera and RCA cable modem.
2 free USB used by SanDisk Cruser and SanDisk MP4 sansa 260. Everything worked OK. After reinstalling Windows from scratch, the 4 permanent USB Hard pieces work OK but when I insert one of the SunDisk the screen goes black and the computer reboots. After reboot I can see that it was a hardware error, take out the SunDisk and Windows Goes on
I have a sandisc 2gb u3 .but i do not work .initialising error is occur
Posted on Nov 21, 2008
    President:
  • 1,901 Answers
Not sure if this is the problem, but I just found out that in some BIOS menus, there are 3 options for your USB controller...Enable...Disable...No Boot.
If you know how to get to your BIOS, it's worth a shot to make sure it is set to "No Boot" if it is an option.
Posted on Oct 09, 2008
Insert cruzer 16gb into usb dell desktop reboots computer
Visit the website http://support.dell.com and download the file called bios for your computer model and run it .. and then try ...
Dec 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Oct 20, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I cannot use my Cruzer 8 GB micro. tried fromatting but cannot complete a format. Just cannot access it. I use XP Pro
1. right click on my computer then manage
2. click on disk management then right click on the drive which you want to format then click format it will forcely format your card.
Oct 13, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My computer which is running Windows XP pro 2002 does not recognize my San Disck cruzer 256 mb memory key. The light flashes upon inserting in to computer and then goes out and then I get message that CPU...
try to disconnect all usb devices and install it again to another port also try to install it on another PC if it workson another PC and yours not then try to remove ur O/S and install a good one like windows Xp SP2
Jun 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
How do i transfer photos from my hp photosmart m537 camera to sandisk cruzer micro usb 2.0 flash drive 2gb.
Connect the HP camera to your windows pc using the usb cable provided. Open My Computer to ensure that the camera is being properly enumerated (given a hard disk letter). make note of the drive letter assigned.
If you have more than one USB port, insert your cruzer micro 2.0 stick into another USB port. Look in my computer again to determine what drive letter was assigned to the flash stick. Open a windows explorer window for each of the locations. One for the camera, the other for the flash stick. Its likely that the picture files are in a subfolder of a folder called DCIM.
Once you locate the files you want to transfer, you can highlight them using the mouse (click/drag a box around the files you want) and drag them to the other open window (flash stick folder)
If you don't have another available USB slot on the compter, you'll need to copy the files from the camera to a temporary location on your computer and then move them to the flash drive. In this case, make a new folder on the desktop and name it temporaryfiles. open that folder. open the drive letter assigned to the camera and copy whatever files you want from the camera to 'temporaryfiles'...
Then power off the camera and remove the usb cord from the computer. attach the flash disk to the newly free'd up usb port and open a windows explorer window to it. drag whatever files you want from 'temporaryfiles' folder into the folder for the flash stick.
I hope this helps!
-Ray
Mar 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer Micro 2.0 problem
Should show up in "My Computer" as a removable drive with letter designator. Then it is simply a matter of drag and drop to copy files using the mouse. If XP doesn't recognize the drive, put it in another USB port, and or try it on another computer. If it doesn't show up then, take it back to the store.
May 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Micro Cruzer Restarts my PC while initializing
Go to another PC and then uninstall u3, to reinstall it go to http://www.sandisk.com/Retail/Default.aspx?CatID=1411.
Hope this helps!
Nicholas CHUM
Apr 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer 4Gb not found on XP
I have the same issue. I have found a temporary solution though. I have a Sandisk 4GB Cruzer and an HP Laserjet 1022N connected VIA USB. When I uninstall the USB Printing support driver from Device Manager then plug in the Cruzer it recognizes it right away. Not quite sure why this would happen though
Apr 02, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 4GB cruzer micro usb flash hard drive
try removing off the launchpad program from the pen drive through an XP system with this software and then try inserting it on the vista as an ordinary pen drive.
Mar 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 2 crashes my system!
Hi marykins,
When you say 'crash' does this mean the system reboots, freezes up entirely, or blue screens?
I've seen similar issues when the USB 2.0 host controller isn't enabled in the System (BIOS) setup. Many devices, such as USB mice and MP3 players and even flash drives, will show up and some will function, but if the USB is required to act as a host controller, devices such as external hard drives and (sometimes) flash drives will either not show up at all on the computer or will crash it.
I'd suggest first looking in the BIOS setup to make sure that both the USB host controller and USB legacy support are enabled.
Ben
Mar 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
131 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
