Question about HP PSC 2110 Color Printer
Hp2110 psc when turning on the the power the Initilization starts and the scanner light moves to the right and keeps clicking (motor not turning off) and gets a error message Initilaztion error. how do you remove the top to look at the unit, could be a encoder strip loose?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
The scanner head is unable to find start position.
You may have to clean the black & white strip under the glass.
HP has a document of how to clean the scanner glass.
Go to http://h10025www1.hp.com
You will be at the can't find page.
Enter c00553775 into the search block.
At the search result page, click on Hp All in one how to clean scanner glass.
Posted on Jan 25, 2009
I am to change the black cart it is showing there is no paper
pl tell me the solution. when we do allinment
Posted on Dec 24, 2008
I have properly connected my HP Scanjet 2400 scanner with my system and the appropriate software was successfully installed, the light is blinking and when we try to scan, it tries to start, but it...
sometimes the power management causes the scanner to act up or fail altogether.
Try: Solution: Disable power management on the USB hubBy default, Window XP tries to disable USB port when the HP Scanjet scanner is not in use to save power. The scanner fails to wake up when called. To fix this problem use the steps below:
  1. Click Start , right-click My Computer , then click Properties . The System Properties window will open.
  2. Click the Hardware tab, then Device Manager . The Device Managerwindow will open.
  3. Double-click the Universal Serial Bus controller branch to expand it.
  4. Right-click USB Root Hub , then click Properties . The USB Root Hub Properties window will open.
  5. Click the Power Management tab.
  6. Remove the check from the Allow the computer to turn off this device to save powercheck box.
  7. Click OK , and close USB Root Hub Properties window.
  8. Close any other open windows.
Aug 28, 2010 | HP ScanJet 2400 Flatbed Scanner
Power up scanner problem
The problem is in the scanner section.There is too mush ash on the mirrors and scanner lamp.You can fix it just like disassembly the printer and pull out the scanner section.Open it cover and inside you'll see the mirrors.Clean the ash from mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Oct 22, 2009 | HP PSC 2175 All-In-One InkJet Printer
When I turn on my 2410 printer the hourglass stays on endlessly.
try uninstalling and reinstalling
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Clicking noise and will not print.
Hi Folks
My 2410 had the same problem and is now 100% functional again
Here is the Solution:
Go to hp.com
at search look for exactly:
!psc 2410 how to clean the scanner"
the first hit is the right one.
There is a complete description, how to do.
The problem seems to be, that the scanner can't calibrate on the right optical marker (inner backsite of the scanner glas) and the motor still retries to move the scanner behind this marker what causes the noise.
Hope it willhelp you
regards,
Michael
May 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
When I turn the printer on, a rhythmic banging sound starts
Is the scanner transport lock engaged?
This is either a screw, pin, Clip, Slideswitch or button that keeps the delicate scanner head from moving during shipment.
Look for it in the back and on bottom. If that isn't it, then the driver circuit for the stepping/space positioner motor is bad and you need a techie like me to fix... or just get a new AIO for $39.95 from Wal Mart.
Mar 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
Hp 2410 just clicking
When you power on the printer.
See if the scanner light move to the right and then keep on clicking.
If this happen, the scanner head is unable to find home position.
You will have to clean the strip under the glass.
If this only start to happen recently, you could unplug the printer and wait 1 hour.
Replug in the printer will at times stop the clicking.
You can go to http://h10025.www1.hp.com
Click on Hp All in one how to clean scanner glass.
This will bring you to the HP document.
Jan 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Scanner failure during the initalization/starts up.
Sound as if your scanner is broken..
Could be something in there stopping it from moving, the motor could be bad.
It might have Home Positioning errors, causing this error.
To get it Fixed? The machine is about 140 dollars on Amazon?
The company I work for, the first hour is 125 (I do not know how much it cost to repair these)
Unfortunately these little ink jet printers are not designed to be repaired. They are considered throw away.
Sorry
Oct 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Scanner bar seems stuck
You will need a torx driver and or phillips to take it apart. Just common sense and patience will get that accomplished. What you want to do then is find the cables that run from the scanner to the circuit boards, disconnect them and reconnect them. Ribbon cables need to be gently removed and be sure when replacing them you don't get any folds in them.
If the that doesn't work, then most likely the board or scan motor have failed. You may also want to look in the scanner and see if the home position sensor, which would be a U shaped sensor has popped out. The clicking is from the scan head trying to find the home ( start) position sensor and not finding it. When it works correctly it drives back until a little flag passes between the light and the photo sensor within that home sensor. Once the light is broken the scan motor shuts off and positions the lamp properly.
Mar 22, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
Fails to initalize
i am having the same problem, did you happend to find a solution for this issue?? please let me know at capahela@hotmail.com or capahela@gmail.com After disassembling mine and realigning the mirrow in the bottom part of the scanner i managed to make it work only once, i really dont think it had something to do with it but it happened. i am desesperate, any help will be appreaciated. i believe that since the motor is a "motor de pasos" that need to be activated by consecutive pulses, the board must be sending these bits non-stop, but i have no clue of whereas how to fix it. thanks in advanced carla hernandez
Oct 03, 2006 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2110 Color Printer Logo
205 people viewed this question
Ben Johnson
