Question about JVC UX-S57 CD Shelf System
CD deck On the lcd screen I have the following message: TRAY ERROR. I know there is a disc in tray number one but it will neither play or eject. Is there a simple way I can make the tray eject so that I can remove the disc??? Thanks
  • keithbarter Oct 11, 2008
    Two solutions I have received are:
    There will be a option for reset .
    Insert a pin in the hole so that you can get the disc out .
    Now this sounds ideal if only I can find the hole for the reset, can anyone tell me where it is located please?
    Thanks Keith
    President:
  • 2,712 Answers
Does the tray make a sound as if it is trying to eject? If so, then try this: Take two thin knives (jewellers' screwdriver will work her as well). Press the eject button and insert the screwdrivers/knives into the gaps on either side and gently try to pull open the tray. Once you get a purchase for your fingers, use them instead to pull out the tray. If you see that the disc inside is not positioned properly and is preventing the tray from opening, use the screwdriver to adjust the position of the tray.
If you do NOT hear any sound when you press eject, then it could indicate a fault with the tray motor or some broken teeth on the gears, for which you will have to get it serviced.
Hope that helps! Please don’t forget to "Accept" the solution if it helped you in any way, or leads you to a fix.
Thank you for using FixYa!
Cheers!
IrishDruid
Posted on Oct 11, 2008
  • Swilin Sampson
    Swilin Sampson Oct 11, 2008
    There is no hole. That is only found on CD/DVD ROM's for PC's and laptops. Try my method. It generally works. If it doesn't, then the only option is to dismantle the deck to get at the stuck CD...
  • JVC Master
  • 19,396 Answers
That means that there is a mechanical error concerning the tray gears
  • Ginko
    Ginko Oct 11, 2008
    To remove the disk stuck inside, unplug power, plug power cord back, turn on the unit, and
    while you are turning on the unit, keep pressing repeatedly the eject button.
    Do this several times, until it works.
    When you succeed in ejecting the disk before the unit starts reading it, you have solved the problem.
    Do not forget to accept the solution if you solve the problem.
    Guru:
  • 558 Answers
Just look to your CD Case, and near the eject and insert button or in the same level a small pinhole is located.. Just insert a paper pin in it.. Hope it will works.
    Master:
  • 763 Answers
There is sir but do this with tools and gloves to prevent accident or something happen. if you can open the cover of your player by using your tools you can get the cd stucked in it. after you open, turn on the power and push off the disc that is in there. you may see a wheel with a gearlike and try to revovle it. im not so sure if its clockwise or counter clockwise but it will remove afterward. or try this one. by the way do this at your own risk. but im doing this whenever a cd stucked on our component dvd. hope that helps!
CHARCOIS
  • 1,183 Answers
Make sure the Disk lock button is not pressed
CD deck - be4e214ed85f97ba48652d2707c5f063.png Prohibiting Disc Ejection You can prohibit disc ejection from the unit and can lock discs—Disc Lock. You can lock or unlock discs when the unit is either turned on or in standby mode.
  • Mandeep  Singh
    Mandeep Singh Oct 11, 2008
    Go to page number 21 or 24 on the user manual , to check how the button looks like
    Thanks
    proton
    Genius:
  • 1,550 Answers
How to update firmware for vizio vbr100
To update the firmware for the Vizio VBR100 Blu-ray player, you need to download the firmware package to a computer with a CD-R or other optical disc burner. The firmware is a .zip file. Next extract the contents of the compressed folder to see the .ISO file. Use the computer program to burn the ISO to CD. Windows 7 and later included this type of program (right click on the file and choose Burn disc image). For other systems, you need a program that can burn image files to disc. Nero Burning ROM is one such program.
Now make sure that the player does not have an optical disc in the unit and turn it off. If possible, plug the Blu-ray player into an UPS (battery backup). Turn the player back on and wait for the No Disc message. Press Eject to open the disc tray and put in the CD with the firmware. Close the disc tray. The Loading Disc message should appear on the screen followed by the firmware screen. Press Select on the remote to start the update process. (Use the down arrow followed by Select to cancel the procedure.) Wait for the update to finish; you do not want the power to go off during this time. The disc tray will open when the "Success" message is displayed. Remove the CD and press Select. The unit will restart. To check your firmware version, turn on the Blu-ray player with no optical disc in the tray. When you see the "No Disc" message, press eject to open the disc tray. Press the digits 7 8 0 4 in order on the remote. Look at the Revision number of the firmware.
Note: not all versions of the VBR100 can have the firmware updated. Also, Vizio no longer supports this model. There are some third-party sites that claim to have the file. Use caution; suspicious code can be added to the file by various parties.
I hope this helps.
Aug 04, 2016 | Vizio Televison & Video
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
DN- S3500 Cd stuck
HI,
Please reset the unit for 4 hours by unplugging all the cords,even the power cord from the unit and then plug them back again after 4 hours.Now try ejecting the disc.Let me know the result.
Feb 10, 2009 | Denon DN-S3500
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Nov 07, 2008 | JVC KD-LX111 CD Player
DVD TRAY WILL NOT EJECT
it is definately jammed and will need to be taken apart and unjammed safely to avoid dammage to the unit
Oct 11, 2008 | JVC UX-S57 CD Shelf System
Wont play dvds, only cds, music and photos when dvd placed in tray, goes through reading process, then ejects tray with an on screen message, unknown disc! With all discs not a certain few. when a blank...
DVD & CD use different wavelengths for the read head. I suspect that the blue laser is out of alignment or otherwise in need of repair.
PhotoCD is a format.
Jul 20, 2008 | LG Televison & Video
Clarion DB175 cd player
The Clarion manual lists 3 error messages.
Error 2-A disk is caught inside the CD deck and is not ejected.
Error 3-A disk cannot be played due to scratches, etc.
Error 6-A disc is loaded upside-down and cannot be played.
Good Luck.
Mar 26, 2008 | Clarion DB175MP CD Player
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
JVC UX-S57 CD Shelf System Logo
432 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
