Question about BenQ FP71G 17" LCD Monitor
Please help me fix this benq monitor
Hi
I have this monitor BenQ monitor Q7T4.
can you show me where to resolder the four transistor.
Do I need to buy new components or just resolder existing ones?
My monitor power is failing, it turns on for 1-2 second then off.
Flashes the logo then off.
My email is tyler.durden404@gmail.com.
If you can help please send some picture and detail instructions to repair this lcd.
thanks
There are many posts that have solved this. Check em out
Posted on Oct 23, 2008
  • martindaniel Oct 23, 2008
    This is a little more useful than other post, four transistors marked SC5707. Search SC5707 on ebay and buy four of these. Replace them as well. Resolder the four yellow transformers. Poor soldering from the factory is often the cause of transistor failure. Check this post, it is similar,
    http://syscon.wordpress.com/2007/07/13/d...
Benq t7q3
look at the 3 amp. fuse on the mainboard! By the way, you can buy very cheap USB light, wich are working with a small lighttube. Use the transistors of their generator!
Mar 09, 2009 | BenQ T705 17" LCD Monitor
BenQ Q7t4 Monitor
Open it up and look for burned or some cold soldre joints. After resolder it should work.
Nov 14, 2008 | BenQ FP757 Monitor
Benq lcd c5707 transistor issues
You need transistors with hfe greater than 300. They are harder to get and you should use the producter`s original transistors 2sa5707.
Oct 18, 2008 | BenQ FP71G 17" LCD Monitor
Benq inverter board schemtic
Post me a picture of the board and I might be able to Help.Normally transistors 2Sc5707 are defective.
Samir.
viziks@gmail.com
Aug 20, 2008 | BenQ FP71G 17" LCD Monitor
LCD panel no display
check transistors Q739,740,759,760.These transistors are near the Yellow inverter transformers.Resolder these transformers and check/ replace above transistors.
Please rate this solution.
Samir
Jun 03, 2008 | BenQ FP737S-D 17" LCD Monitor
Monitor goes on/off in 2 seconds
Problem is related to Invertor .If you are Technically able ,resolder power transistors 2sc5707 on powerboard near invertor transformers.
Please rate the solution and provide feedback.
Samir
Jun 01, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP731 17" Inverter transistors
T751,752,753,753 are the transformers to be resoldered ,and resolder Transistors Q759,60,39,40,43,51.
Please check them with a multimeter if you are adept .
Samir
Apr 16, 2008 | BenQ FP731 17" LCD Monitor
Q7T4 monitor
I have the same trouble,with the Benq Q7t4 power, but can you tell me how I can get it apart, I have taken all the screws out but can't seem to dismantle it.
many thks colin
Mar 31, 2008 | BenQ FP731 17" LCD Monitor
Secondary monitor
When you first switch on Does it show Benq?If not the inverter circuit has failed.If you are technically able you can try resoldering transistors on inverter board.If your display is black all of the time transistors could have failed as also related fuse etc.
And yes please check with BenQ Normally these have a 3 year warranty.
Mar 05, 2008 | BenQ FP757 Monitor
Benq FP731 17" monitor goes Blank after start up
Change the 2SC5707 transistors and electrolytic caps in the inverter
section. Also check the 3A picofuse, and resolder all transformer
pins
Aug 09, 2007 | BenQ FP731 - 17" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
750 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
