Question about Elmo Projectors TT-02U Camcorder
Elmo TT-02u, Random freezes
The camera does random freezes of image. When this happens the buttons; e.g. power, menu etc... are unresponsive. You have to physically pull the power plug.
  • Monimacaroni Dec 11, 2008
    We did pull the plug, and this worked for awhile but now the freezing happens sooner and more often.
The problem is a set bad capacitor that must be replaced by the factory. The units are very critical on the exact amperage that the power supply delivers. We have hundreds of tto2 and a few have had this problem. Elmo is aware of the problem and your warranty should cover the problem.
Posted on Jan 06, 2009
I open image mate and the laptop says that no document camera is connected. I have changed the cords and laptop still does not read the camera. The elmo will still project an image on the projector so...
I had the same problem with a TT-12 model. Dave from ELMO provided the resolution:
1. unplug the usb cable from your PC
2. on the ELMO:
a. Press MENU > PREFERENCES > USB MODE
b. ensure that APPLICATION is selected
c. exit the MENU and reconnect the USB cable to your PC
Oct 09, 2012 | Elmo Projectors ELMO TT02RX DIGITAL...
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Apr 14, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
Green camera light is flashing and image will not project. What can I do?
If you can post something offering a bit more detail, I can probably help you. Or you can call 1-800-896-3566 and ask to be connected to a tech. The TT-02rx comes with 5 year warranty.
Elmo acreen goes off after a few minutes and says"unable to acquire live monitor image"
check switches on back of unit they should be set to RGB for computer or video projector
Sep 08, 2010 | Elmo Projectors TT-02U Camcorder
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen in ON mode at random occassions
Remove the card and the battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on. If the screen comes on, go into the menu and scroll to "reset" and follow the on-screen instructions.
Oct 02, 2009 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Computer crashes while playing games
try update your VGA drivers in the nvidia support page, or using software "drivers detective" or etc.
if its not work, u have to check your video card, maybe overheat..
or u can try to format your OS, it can be some support files are missing or corrupted....
or the last one, your VGA card is broken or maybe does not compatible with the motherboard u used...check the specification of it, whether the game, VGA, or motherboard u used
May 30, 2009 | Microsoft Windows XP Home Edition
Teacher Tools Elmo TT-02S
check the 2 little switches on the back it is possible that they are in the wrong position. for a pc or video projector the switches have to be in RGB.Check those switches and turn it back on .That is most likely your problem
Dec 20, 2008 | Elmo Projectors TT-02U Camcorder
Elmo Projectors TT-02U Camcorder Logo
713 people viewed this question
Top Elmo Projectors Video Cameras Experts
Are you an Elmo Projectors Video Camera Expert? Answer questions, earn points and help others
