Question about Gateway GT5014 PC Desktop
Computer shuts down after being on for about 5 min.
I have a GT 5014 media center edition computer that works great for about 5 minutes and then we get blinking blocks on the screen bofore it shuts down and reboots. If I need a new mother board where can I get one?
    Master:
  • 505 Answers
Go to system properties. Click on the advance tab. Then click on Start up and recovery. Uncheck the box Automatically restart. You will get an error code. Refer the error code for further troubleshooting. For motherboard you will get from Bestbuy, Wallmart, Radioshack. bestbuy will be the best option. they also have technician who can help with the same
Posted on Oct 09, 2008
    Problem Solver:
  • 5 Answers
G'day
This sounds more like an overheating issue than a motherboard problem. This first thing you need to do is to enter your bios when the computer starts up. you can enter the bios by pressing the DEL, F1 or F2... it all depends on the manufacturer. Once you enter the bios there will be a hardware monitoring section which display voltage, cpu tempreture etc. check the cpu temp and see how much it hits.. if it reaches say 80-90c and the computer cuts off then it's a temprature problem. I've posted the links to the online manuals.. you will need them.
http://support.gateway.com/s/PC/R/5395/5395ul.shtml
If it is the above problem:
open the side panel on the pc and check if the processor fan is operational. Since this is a branded machine your pc will most probably have a green duct that pulls air over the heatsink.
it should look something like this (check the link) :
http://support.gateway.com/s/CASES/WME1T493-001/WME1T493-001iv.shtml
Now what you need to do is remove that green duct carefully (should be held by clips). make sure you do this with the cpu turned off.
ok now you should see a fan. if you don't that means the fan on the rear of the case has to do all the work. Now turn on the pc and check if both or if there in only one fan, if it is operational. if even one does not work replace it with a new one.. if both fans are operational then it might be that the heatsink is not locked in place. if so lock it in place.
if it's none of the above check if you have a pci-express vga card installed instead of the onboard. if so check it vga card has a operational fan. but it's very unlikely that the cpu will reboot because of a vga card.
if you do need to buy a motherboard check ebay or newegg.. they should have them in stock.
hope this helps
cheers
kbh
    Master:
  • 538 Answers
Hmmm..sounds thermal all right..did you check to see that the fans are clear first
I have a HP Media Center PC m1264n desktop.I can turn it on and 1 minute or maybe 5 to 10 minutes into it,it will just shut down,but the power led light on the front of the PC stays on.I reboot it and it...
Is it going to sleep or is it actually shutting down? Do you have to push the power button to turn it back on? Just a thought - if you have Windows 7, go to Start, Control Panel, then System and Security. Now check 'Change when the computer sleeps' under Power Options. Under Edit Plan Settings, what do you have for 'Put the computer to sleep'. Does '20 minutes' show up in the box? Open it and change it to 'Never' and then Save changes. If this didn't help you,maybe someone else can.
Sep 04, 2010 | HP Media Center m1264n - 3.0Ghz 1024MB...
Want to restore vaio lap to original factory setup ?
sony VAIO computers uses a hidden partition one the harddrive which is VAIO recovery center
  1. restart the computer then press F10 key repeatedly for 5-7secs when you see the vaio logo on the screen, until you see loading files or edit boot options
  2. if you get the edit boot options screen, press enter
  3. it will load the Vaio recovery center
  4. select Restore c: drive
  5. disconnect all external devices before starting the recovery, also turn off the wireless switch if there is
  6. doing the recovery may take up to 45mins or 1 hour with random restarts. it will install the os, driver and programs that came with the computer
Dec 24, 2009 | Sony Computers & Internet
Help needed !!! opened Windown media center earlier today, and now even with all applications shut down, the file wmpnetwk.exe is constantly using ~ 50% of my CPU. I Have ended the process with task...
Wmpnetwk.exe is a media player network sharing service. It is annoying and useless(as you have already noticed).
Click start->Run->Type in "services.msc"(without the quotes). Then click on the services tab, and uncheck the box next to wmpnetwk.exe. Click apply, close the configuration utility and reboot your computer. If you ever want to start the media sharing service again you can start it from windows media player.
Hope this helps,
Sai.
Dec 18, 2009 | Microsoft Windows Vista Ultimate Edition
My media center stopped working due to error clr20r3. Could someone help me with this. Thanks.
http://mymce.wordpress.com/2009/07/17/fixing-clr20r3-issue-in-windows-media-center/
Is a site which has some suggestions, every one seems to say the same thing.
you could also poke around on google and use the search of MEDIA CENTER VISTA ERROR CLR20r3
Seems a very common error.
Nov 11, 2009 | Microsoft Windows Vista Ultimate Edition
Philips LS1400 - Boot Sector Virus switching itself off randomly
Richt click on the hard drive -> choose properties->In properties window click on tools tab->in error check column click on check now->just check both the check boxes on check disk window- then click on start->after check completes restart your computer
Jun 19, 2009 | Microsoft Windows XP Media Center Edition...
Pc working slowly with 2gb ram
Step 1:-
Go to
Start > Run>
type "msconfig" >uncheck all except ur sound & display drivers then click Apply > Ok
Step 2 :-
Right click on My Computer Then select advance tab
>performance settings>select advance>click Change > click on custom size then double the values then click ok
And Ur Done
May 23, 2009 | HP Pavilion Media Center a1320n PC...
My screen shuts down automatically
hiiiiii friends
some virus on your pc .....remember you format it total driver........
Nov 10, 2008 | Microsoft Windows XP Media Center Edition...
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Oct 05, 2008 | Microsoft Xbox 360 Console
Computer monitor
try resoldering the vertical output IC.
May 11, 2008 | Gateway GT4022 PC Desktop
Windows XP Unusually Slow Startup
plz go to msconfig and disable all item except the antiviruse in the startup tab, then go to my computer propeties ,click on advance then click on performance then select adjust for best performance(visual tab) then go to advance tab and change the page file to 1024 for both(min and max) then do a full scale system scan for viruse
Post your findings
Apr 28, 2008 | Microsoft Windows XP Media Center Edition...
Gateway GT5014 PC Desktop Logo
115 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
