I have a IIIxe Palm. The cradle which I have has a 9 pin serial connector. I bought a new laptop w/ Windows XP, which requires a usb port. Where can I buy a cradle with usb that will work w/ my system. Best, Jim Voneman
I'm sure you have since upgraded your phone. But just in case, you should be able to find a serial to usb connector from the link below.
Link
Posted on Jun 20, 2009
Unable to connect with desktop through usb cable
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
What is a serial port and where is it on the p67 mb
a serial port is a 9 pin (DB-9) connector for serial communication (RS232) used by modems, mouse, etc... In older machines you had a DB-25 (25 pin connector) as well usually situated in the back of the computer near the printer port (DB-25 connector) but femail (25 holes insdead of 25 pins)
Hope this helps!
Aug 06, 2011 | ASUS P4P800-VM Motherboard
Where is the printer port on my acer aspire 7551-2961?I did not get an user guide and am a lost senior citizen trying to communicate with my grandchild.MCV
Most printers now use the USB port instead of the older parallel ports that has several input/out pins. Some printers (new-out-of-the-box) do not come with the USB cable, therefore purchase one for your printer if it requires a USB cable. The computer should have more than one USB ports to plug into.
Nov 01, 2010 | Computers & Internet
Customiser 2000 will not connect to a laptop as it has a 9 pin serial port (female) and the laptops have a 15 pin (female) I have bought 2 different cables but none work it just says serial port did not...
Are you using a USB-to-serial adapter?
I *think* what the problem might be is that the COM port's not been set in Customizer. Within either of the Easy/Customizer apps, go to ScanCard>Communication Settings ... you'll open up a dialog box within which you can set which COM port your cable's going to use.
If you're compie savvy, you can go to the Windows Start button on Task bar>Control Panel>System>Device Manager>COM ports and SEE which COM port your cable's using.
But until your software knows what COM port your cable's using it will NOT recognize that you have one installed.
Please let me know if this doesn't help! Or if there's anything I can help with!! :)
Aug 01, 2009 | Janome Memory Craft 9000 Computerized...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Palm IIIxe backlight
No, the backlight seems to be about the first thing to go when these screens fail. You can possibly get a replacement screen from pdaparts.com.
Apr 01, 2008 | Palm IIIxe Handheld
Windows Vista won't boot
Windows vista is not included in product min OS requirements technical details. That may be the problem.
Product Features
  • HP DC195A Serial/Parallel Multi I/O PCI Card General Features: Serial/Parallel adapter PCI interface
  • Easy to install Fast transfer rate (430 Kbps) Connectors: One (1) Serial port (9-pin D-Sub DB-9)
  • One (1) Parallel port (25-pin D-Sub DB-25) Regulatory Approvals: FCC CE
Technical Details
  • Model: DC195A
  • Item Package Quantity: 1
  • Hardware Platform: PC
  • networking_feature: Parallel/serial adapter
  • form_factor: Plug-in card
  • Network Interface Description: PCI
  • Connectivity Technology: Wired
  • Data Link Protocol: Parallel, RS-232
  • Minimum system requirements: Microsoft Windows NT, Microsoft Windows XP Home Edition, Microsoft Windows 2000 / XP Professional
  • Depth: 4.7 inches
  • Height: 3.5 inches
Jan 22, 2008 | HP (DC195A) Serial Adapter
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
