Question about Panasonic Lumix DMC-LZ2 Digital Camera
The lens stays extended when power is off
When I power on a message says " Please turn the camera off and on ".
When I turn it off the lens stays extended. When I turn it on the same message is displayed again and the camera does not respond to any key.
  • 420 Answers
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Posted on Sep 11, 2010
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
The camera turns on then shuts back off again
hat type of problem is usually associated with a lens extend error.
It is usually caused by weak batteries or dropping the camera.
Keep your eye on the LCD screen when you turn the camera on.
Do you see any type of error message?
Now turn the camera on again and help the lens extend by gently pulling on the lens as it extends.
Does the camera stay on when you do that?
Sep 24, 2010 | Kodak EasyShare Z740 Digital Camera
Lens error message? Worked fine the last time I
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jul 27, 2010 | Canon Powershot A2000 IS Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Error message E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 12, 2009 | Canon PowerShot S1 IS Digital Camera
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Dec 25, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
105 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
