Computers & Internet Logo
jimmie dixon Posted on Jan 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My acer aspire 5100 stuck after running windows the message says autochk program not found - skipping autochk and it keep`s starting over with the Acer screen as startup and the black screen with the cursor butonly for 2 to 3 secnds and it`s back to startingf windows and it keeps repeating.
Anonymous
Level 2:
New Friend:
  • Expert 108 Answers
  • Posted on Jan 08, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
108
Questions
Helped
16504
Points
193
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Jan 13, 2009
SOURCE: Acer 5100 Motherboard
the best place that i can think of would be www.laptops-motherboard.com
If you are looking for something locally, i would suggest finding a smaller (mom and pop) computer store... not one of the big ones(best buy/circuit city). hope this helps, please rate if it does...thanks
Anonymous
  • 404 Answers
  • Posted on Mar 09, 2009
SOURCE: Acer Aspire blank screen
yes its a virus that's blocking explorer
a complete clean xp installation is needed to fix this problem.
rate plz
Anonymous
  • 60 Answers
  • Posted on Sep 19, 2009
SOURCE: Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
ruwidperd372
Rudy Widy
  • 279 Answers
  • Posted on Apr 10, 2010
SOURCE: how to get back my acer webcam aspire 5100-3825 and how to set it
if you have the webcam driver installed, you only need to install the webcam software. Try Cyberlink YouCam3, download link:
http://www.topshareware.com/cyberlink-webcam/downloads/1.htm
Anonymous
  • 33 Answers
  • Posted on May 15, 2010
SOURCE: My acer aspire 5100 is very slow.Any tips!!!
may be your problem is belonged to specification system on your computer ! if your Memory Ram is lower than 512 MB, just you must install Windoes XP Service Pack 2 on your PC, after finalization the XP OS find to drivers for the hardware from device manager and update all drivers and restart your PC,... if with this practicing your pc same before is worked slowly, I think your Hard Drive got Bad Sector you have to use Hirnes Boot to slove all problem inside your HDD .. Hirnes boot an CD is contained some great application working from DOS for checking hard and Motherboard and ram uitility and recovery and some program else .. you just use hard tools > then Active Kill Desk > then select your HDD by get down Arrow on your Keyboard then press F10 key on your keyboard ..after pressing that button an window box will be appear ..come down to start erasing ... in this process you must wait after 30 Min even 15 percent will be erase .. %15
after complete erasing press ESC button on your Keyboard then remove Hirnes boot CD and bring back Windows XP to your CD room begin installing OS from first ..
you will be sure after this practice your computer will be faster than now ..get it hirnees boot from here http://www.hiren.info/pages/bootcd read more information about it
Testimonial: "Thanks I'm gonna try it right now!"
2answers
I have an Acer one aspire that won't start. I keep
Dear user,
Please try to restore it to factory mode or re-install OS
Tons of applications running on an Acer Aspire 5100 lap top. What is a good list of required ones?
The good news? Your going to learn alot about which programs are on your Laptop.
The bad news? Your going to be doing alot of searching on the internet for the processes that are running on your Laptop.
Hit ctrl, alt,and delete, at the same time, this is called " the three finger salute", to bring up your task manager. Hit the processes tab, there you will see a list of the running processes, just do a search of each one on the internet which will give you an idea of which ones you can shutoff and which ones you need to keep running.
This site is good for getting info on your processes,
http://www.processlibrary.com/
If you would like to keep some of them from starting up when windows starts. Hit your windows key and either start your run dialog or your search programs and files button, type in "msconfig" without the quotes, look at your startup tab and just uncheck the programs that you know you don't want to startup.
Good Luck
My Acer Aspire 5100 tells me that my USB port are
Check the driver status of the USB. You can do this by accessing the Device Manager. For users using Windows XP, just click the Start icon. On the Run box, type devmgmt.msc. You can also do the same with Vista.
Next thing, check for devices with an (!) sign with a yellow background. These devices needs driver update or correct driver should be installed.
For a start, you can do a Windows Update. Click Start, All Programs, and then Windows Update. This will download patches for your system.
2helpful
Acer aspire one ZG5
sure you can ..
you should look for Acer Erecovery managment in all programs.
that will help you is restoring your system.
Thanks
Kevin
Acer Aspire 5100 Freezes
I am not sure which you are talking about either. But I will venture to say that I had a similar problem once where setup would not complete on my system either. I initially thought that I had a bad or dirty disc but later after running a few tests, I found out that my HDD was full of bad sectors. Thus I ended up replacing the HDD and all is well. I would try running a stand alone formatting software or you could try doing a complete format vs. a quick format during Windows setup. If setup still won't complete after a complete format then run a surface scan or a HDD regenertion program to verify the integrity of the drive. This will tell you if you have a bad drive or not.
2answers
Laptop Overheating
i have read lot of same type of problems,with acer,if it is under warranty send it before end, there is fee of 449.00 for out of warranty notebooks. my 5100's have problems,very unhappy! with acer good-luck!
Start up
plz format ur os i think there is a problem with ur os...
2answers
Failed programs
is this a windows error message or it is your webcam software? If this is a windows error message the best ay to fix it is to recover your computer to an earlier date by running the system restore utility in the systems tool folder. if its your webcam software i would uninstall it and re-install it back again. please advice.
3answers
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
2answers
Acer Aspire 5100
This is a duplicate posting, the main discussion can be found here: http://www.fixya.com/support/t133152-acer_aspire_5100
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
