How do you remove the dasher (agitator) from this model. (it has a detergent feeder in middle).
Remove the dispenser cap by pulling it straight up. Under the dispenser cap, there may be another cap. If so, remove the center cap exposing the agitator bolt. Using a socket and ratchet remove the agitator bolt and the top half of the agitator can be lifted out as one piece. With the top portion of the agitator removed, grasp the lower agitator by the bottom flanges and pull straight up. The remaining section should lift off the center post. For a helpful illustration of what I'm talking about, go to searspartsdirect.com and type in your model number as "110.82881110". Go to the "Agitator, Basket and Tub" heading. There's an exploded view illustration of the agitator and all the components. If you require parts, all the part number and pricing information is available, as well. I hope this helps you.
PS When re-installing the agitator DO NOT over tighten the agitator bolt. This can cause damage to the agitator and create slow rotation problems. Just make sure you tighten the bolt snug, and then give it about a 1/4 turn.
