Question about Maytag MZD2766GES Side by Side Refrigerator
Water filters and tubing clogged
My SxS fridge runs great, except my town water has sediment in it and it's clogged up the water tubes so water just trickles out and ice doesn't form. The maytag repair man said it's not covered under warranty because it's the town water problem, not a maytag problem. Town says it's not their problem per by-laws. So, I asked the repair man what to do and he said not to drink it until the water clears, but the tubing is pluggeg, you can see the sediment in the tubing. I asked him if the tubes can be replace, he said some can and some can't, but it's not under warranty. OK...so now I can't find the tubing in the manual on-line. I'm not sure what to do at this point, but this will be only 5 years old in Nov 2008 and no longer under warranty. What do I do? It's a case of pass the buck.
Thanks,
D
If you can disconnect the hoses try to reverse the flow of water, possible this will loosen up the sediment.
Posted on Oct 09, 2008
I put a new filter in my Sansung Refrigerator and the water taste worse than the old one, why?
I agree with Gramps... the system needs to be flushed, but one question... why did you change the filter in the 1st place... was it cause you had a smell or taste in the water AND ice, or the filter light came on?? I would remove water line going to ref from house plumbing... run water in bucket for 2 min, then take a small taste to see if good..If water taste good, then hook water line back up to ref, and run water at the door for about 1/2 gal, then taste and smell water to see if it passes... If still have problem, you are going to have to replace filter head and/or water reservoir.... But before i did that i would contact Samsung to get their take, depending on age they might send parts at no charge to you the consumer....... Ken Hawk
preferred Samsung servicer
Jan 20, 2015 | Samsung RF265AA Bottom Freezer French Door...
I have a Kenmore Coldspot Fridge. The icemaker is leaking in the fridge and running water all over the inside causing ice to form every where. I already replaced the water fill tube. I noticed after the...
Yes exactly that is the water inlet valve thats causing that its not fully closing yet its staying open a little and seeping water through it.
GENE
Sep 09, 2011 | Refrigerators
KitchenAid side by side refrigerator doesn't make ice, very slow trickle cold water in door. Removed automatic ice maker and removed ice in discharge tube and reinstalled same. Problem not resolved. ...
check for a kink in the plastic water delivery line. If line is kinked do not bother to streighten it out. Replace it. Once the line is weakened it could break and cause flooding. When reinstalling the line and moving fridge back into place ensure that the line is not bent or kinked.
May 10, 2011 | Kitchen Ranges
I have a Frigidaire professional side by side fridge model# LPHS2687KFO water is leaking before entering ice maker thus the ice maker is not working, water is leaking in freezer
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Apr 25, 2011 | Frigidaire Refrigerators
There is a leak at the front of refrig clear water and all water lines have no holes and only happens in summer time
Just fixed mine w/the same problem! Unplug the fridge and pull it away from the wall. Check that your drain hose is not clogged: it runs down the back of your fridge and you need to disconnect the tubing from the fixture where it goes into the middle of the back of the fridge, by turning the fixture approx. 1/4 turn counterclockwise. This will help disconnect the tubing and will allow you to pull out the fixture which connects to the internal drain. I had to run a pipe cleaner and hot water thru this fixture, which has several S-curves in it that traps sediment. Check the tubing too. If these aren't clogged, your internal drain may be iced over. You will have to empty the contents of your freezer, and remove the icemaker and back panel of the freezer (my screws were 1/4-inch ratchet type). There is a drain hole at the middle bottom of the back wall. Check for ice and pour in very hot water to melt it. Check the inside of the bottom part of your fridge to make sure water isn't leaking in from the cooling vents at the control panel. If neither of these tasks works, then I don't know what to tell you! Good luck!
Jul 19, 2010 | GE J Series 20.6 cu. ft. Top Freezer...
Ice tray filler tube freezes up and clogs up so no water goes into tray
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
May 22, 2010 | Amana SXD524VW Side by Side Refrigerator
Ice maker does not produce ice, it was clogged with ice. so i fixed that . the tube coming down from the top was what was clogged frozen . red light is flashing twice repeatadly. need info to fix. thank...
Jan 27, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker has ice forming underneath where ice cubes drop. It is leaking water from somewhere?
Nov 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water keeps pooling on the second shelf in the refrigerator, and I can not find the source.
Water collecting inside a fridge (that doesn't have a water dispenser in the fresh food compartment) is usually a sign of a clogged tube that directs water collected during the defrost cycle of the freezer coil. The defrost heater melts frost / ice that collects on the coil and water drips into a pan directly under the coil in the freezer compartment. The pan has a tube that allows the water to flow into a pan at the bottom of the fridge, where it is generally evaporated by the heat of the compressor.
You'll have to access the coil and pan (probably behind the back wall of the freezer - but check your model first!) and clear the obstruction from the tube. It is not uncommon for bacteria, mold, etc to grow in the tube. After clearing with a blunt flexible snake - run 4 - 6 ounces of a 10% bleach 90% water mixture to kill any growths remaining in the tube.
Sometimes, ice can form in the top inch or two of the tube, too. A turkey baster can be used to direct hot water into the tube to quicken the thaw process.
If there is water dispensing in the fridge, check all lines and filters in the compartment for spits, cracks and leaks. Repair / replace parts as needed.
Do not perform these steps with the power on!
I hope this helps!
Oct 28, 2009 | Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
91 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
