Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice build up on bottom of frodge/behind bottom drawer. ice builds up and them water [pools at bottm and drips ont floor. I've pulled drawer out. defosted but, ice builds up again.
  • traciH May 04, 2009
    I have a build up of ice on bottom of ge profile freezer...I have used a blow dryer to melt and take out ice, then, poured hot water down drain to melt as well.  This is now becoming a "Sunday" job added to my list!  If I don't do this, the water will continue to drip from the freezer build up onto my new wood floor (recently cracked from the water build up).  After months of my husband blaming the kids and I for not closing the freezer properly, he finally gets it that the problem is the freezer.  HELP! I was not aware of a drip pan that the freezer drains into...and someone said to put a wire down there and then add the water.....????
  • 21 Answers
There may be a drain tube for the frost free located in the panel behind bottom drawer. The drain tube sounds to be full of ice. You will need to remove all items from freezer and use a hair dryer to melt the ice fully. Also remove the cover panels so you can tell when you get the drain unplugged. Pour hot water down to make sure the line is melted and free of other pluggage.
Posted on Nov 13, 2008
  • 94 Answers
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Posted on Oct 14, 2008
Whirlpool dripping water from freezer drawer
See inside freezer box floor. Do you see Ice layer build up. If so then your defrost drain line is clogged.
Sep 23, 2014 | Whirlpool Refrigerators
I have a top freezer/bottom refrigerator-6months old-no icemaker hooked up. There is water dripping continuously into the refrigerator compartment-some of it freezes and the rest accumulates in the...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 17, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Condensation building up under crizper drawers icing up somewhat and overflowing out onto floor.
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
oldtech2332_6.jpg-->-->
Aug 16, 2011 | Frigidaire FRT17B3A Top Freezer...
Water is pooling under drawers in bottom of refridgerator and drips behind fridge from the top of drain plug. I took out plug on back of fridge and clean it out, it appeared to be plugged. I do not know...
The drain pan would located at the bottom of the refrigerator near the compressor. You can often remove the drain pan from the front after removing the grill or from the back after pulling the refrigerator out from the wall and removing the access cover.
Aug 02, 2011 | Refrigerators
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Kenmore refridgerator with freezer on bottom leaks water from bottom and I have ice build up in freezer and it's suppose to be a frost free freezer?
I had the same problem with my refrigerator/ bottom freezer. It is a Kenmore and would build up ice in the bottom and would eventually drip water on the floor in front of the bottom drawer. I solved the problem by doing a few different things. First I took off the back cover to see where the drip pan was located. Look for the drain tube that goes into the drip pan and in my case cut two plastic ties to gain a better angle for my next steps. I took a turkey baster and a cup of hot water and shot it in the drain tube several different times. Then I took a string trimmer line (pretty thick) and pushed that into the drain tube as far as I could get it and worked it back and forth. My final step was to blow air into the drain tube in towards the freezer at which point I could hear the ice in the icemaker blowing around. The following day the water was draining into the drip pan and not into the bottom of my freezer :>)
Sep 16, 2009 | Kenmore 19.7 cu. ft. Bottom Freezer...
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice build up on the bottom floor of the freezer
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Nov 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
368 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
