Question about HP Officejet 5610 All-In-One InkJet Printer
After printing, the page has a line close tho the middle..
I'm not sue if this printer has a "Drum" I know older ones do and that was the problem ...but never had this problem before with the line down the middle of the page. Whats up?
    Novelist:
    Scholar:
  • 111 Answers
I couldn't find an exact solution to your problem, but suspect that the issue has to do with how the in carriage is calibrated. HP.com published a web page for this product that shows how to perform a series of diagnostic tests that may lead to a solution:
Streaks or Lines on the Printed Page
Although you don't mention a problem with copying as such, this next web page seemed related enough for me to include it:
White Lines Through Copies
Hope this helps you track down and solve the problem. Good luck.
Posted on Oct 10, 2008
I have canon lbp 2900 printer when i print first line shadow is also printed in the middle of page and middle line shadow is also is printed in the last of page. and some of line shadow is also printed.
Repetitive ghosting defects like this are caused by either a bad drum in the cartridge or a damaged or worn fuser assembly. Try a different cartridge first, but make sure you print at least 50 pages to make sure that any toner residue is cleaned of the fuser in the printing process. If the defect is still there then you will need to either repair or replace the fuser.
May 06, 2011 | Canon LASER SHOT LBP-2900 Printer
I have a 525DN Brother Printer which has started printing a line in the middle of the papers and dumping ink out of the left side of the cartridge - do you know what may be wrong?
Thin line? Print a diagnostic page (3 pushes on the go button) and try changing the toner cartridge or drum, depending of the page says.
Nov 30, 2010 | Brother HL 5250DN Laser Printer
Hello, my problem is, when i print a copy I receive a blank line, it seems like the ink is finish or the middle of the ink is finish or don't have ink. don't know what to do I tried to clean the toners and...
If you are seeing a white line down the page in one or more areas, but it is printing fine in others it is most likely your toner or your drum. Try taking the toner cartridge out and shaking from side to side to evenly distribute the toner and break up any lumps that might have formed while it sat around. If that doesn't work take out your drum unit and look at the drum roller (don't touch it!) if you see lines or color differences on it then it might need to be replaced.
Aug 18, 2010 | HP LaserJet CP1515n Printer
Two white gost lines in the middle on the middle of the page ( one two millimeters wide) , the other 2cm away and one ml wide with shadows There are several other with similar distance from eacjh other but...
Something is wrong with your printer -- part of the drum is *NOT* holding the magnetic-charge that the laser should be creating. So, none of the ink "sticks" to the paper, resulting in a WHITE strip.
Take the printer to a qualified technician, for proper trouble-shooting & repair.
Apr 05, 2010 | Konica Minolta magicolor 2400 Laser...
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
Brother9440 black dots appearing in line close to middle
it is problem drum spot open ypur printer drum unite and chack it or buy new one
Jul 23, 2009 | Brother MFC-9440CN Laser Printer
Lines in middle of page
Open the right side then open the hot part (The fuser located above the drum cartridge with a flash lite look at the to rollers is ther a line on one of them BE CAREFUL VERY VERY HOT if on. IF so replace the fuser try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 24, 2009 | Minolta Di2510 All-In-One Laser Printer
Line down the middle
The drum cleanig blade of your Samsung has unfortunate a crack (or a scrape) in the middle and in that place it does not clean the drum between rotations, so there you'll have toner powder remaining from all the letters in the middle that where not cleaned from the drum.
So, you should replace the drum cleanig blade or ask a professionist to do it.
Replace the drum as well, if you are there, it's better to give a new drum to a new blade.
Rate the answer and et me know if this was helpfull!
Feb 13, 2008 | Samsung ML2250 Laser Printer
Black line in center on manual feed
If you are getting marks on copies but not prints then it is the small slit of glass prior to copy glass that is marked/dirty
Oct 23, 2007 | Brother DCP-7020 All-In-One Laser Printer
Printing with a line
well the problem is related with the drum, but on that printer i´m not sure if the drum and toner are one part, if it is you need to replace both (that are one single part), if they are separated you need to replace only the drum. good luck
Sep 11, 2007 | Brother HL 1440 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
137 people viewed this question
Ben Johnson
