Question about Xerox WorkCentre M15i Laser Printer
Does m15i have capability to share fax line with land line????
I need to share my main line with my fax line. The phone company put the fax line on this line. It does not recognize custom ring. Is there a setting for this?
Thanks
Gale
    Master:
  • 538 Answers
Hmmm...that is standard on that unit..do you have a user manual for this xerox model
Posted on Oct 09, 2008
Cannot get the fax to work... need to know correct hookup please
ok look on back and take your main phone line and install where it says line in. Take the next spot and put your land line phone cord and install it in line out. If you have dsl for internet get a "t or y" and put on line out. always make sure the fax has the first line in.
Jan 03, 2011 | HP Officejet 4315v All-In-One InkJet...
Hi. I have a Xerox M20i. The fax machine will ring, but then immediately hangs up. I have reset the memory and the DIMM chips as suggested by Xerox. The phone line works as the machine can fax out. Help...
Is your phone line in the " line" jack and not the ext jack?
If the line is digital it will do that.
If the phone line voltage is low, the line current low that will also cause the problem.
In your fax settings. Is ECM turned ON.
Is Junk Fax OFF.
Secure Fax OFF.
Delay Fax OFF.
If your phone line is weak, it will cause that problem.
Jul 13, 2009 | Xerox WorkCentre M20i All-In-One Laser...
How do I manually receive an incoming fax? I do not keep it on Automatic Receive because it is on my voice line, not a dedicated fax line.
When the phone rings, pick up the external handset. When you hear the fax tone come over the line press the Start button and hand up the handset.
Apr 14, 2009 | Xerox WorkCentre M15i Laser Printer
Cannot send faxes when using cable company's digital voice modem
Fax machines must have a standard analog phone line. They won't work on a digital line and can actually be damaged if hooked up to one.
Nov 09, 2008 | HP LaserJet 3050 All-In-One Printer
I can send faxes, but cannot receive faxes.
Thank you for specifing your connection>
When you have a shared fax line it is import to have a Distinctive Ring Pattern which will differenciate the type of ring patter to recieve voice calls and Fax message.
All You need to do is get a distinctive ring pattern from your telephone service provider (AT&T) and setup your fax machine as per the ring pattern provided by your service provider.
All you need to do is set your rings to answer in youe phone to Rings 4 in your Phone.
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate basic fax setup> Press Ok and set the Ring Pattern to Number 5 or 6> Press Ok and cancell to come to the main menu
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate Advance Fax Setup> Locate Distinctive ring pattern and set it to the ring pattern which your Telephone service provider has alloted i.e Single Ring, Double Ring or or Triple Ring (Whichever is applicable)> Nd press Ok and cancell to come to the main menu.
Then you will be able to receive fax message voice cals and voicemail without any interuption.
Good Luck
Sep 25, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Receiving a fax on my Lexmark X6170
for these companies, try disconnecting the phone tremporarily to see if thsi is interferring just with these particular faxes. Sometimes if a company's fax is set to phone/fax, it may be trying to call you first beacuse ths would be the default settings. If it detects no phone it may by default accept your fax no problems. Hope this helps.
Aug 18, 2008 | Lexmark X6170 All-In-One InkJet Printer
Can't receive faxes
Do you use DSL for you internet? You may need a phone line filter
Jun 18, 2008 | Xerox WorkCentre M15i Laser Printer
Setup computer w/ faxing
Yes you can. You need a fax modem which you can get either one of the following:-
1) external fax modem which plugs in to the serial port of your pc
2) an internal pci which sits on one of the ports on the systemboard which is easy to install.
May 03, 2008 | HP Officejet 7210 All-In-One InkJet...
Jx300
Contact the cable company, as they obviously have something mixed up in the installation and/or wiring of the new setup.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Feb 05, 2008 | Canon FAX-JX200
Receiving a fax
Faxes fail intermittently or with only one fax number
  • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
  • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
  • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
  • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
  • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
  • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Xerox WorkCentre M15i Laser Printer Logo
57 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
