Question about RCA DRC8030N
Machine stuck on hello...pressed power & stop to no avail
If the power button is held for 5 sec or more the unit will turn off and shows clock (which is working) but whenever open/close or power button is pressed the display shows sequencing 'HELLO' and nothing else will work.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
Hi. The most common culprit for this HELLO message issue is a faulty DVD-RW drive. To make sure that this is the case, you will need to replace the DVD-RW drive with another DVD, DVD-RW, or another spare hard drive in it's place to make sure the unit powers on and gets past the Hello message. Just make sure the replacement is configured correctly via the master/slave jumper on the back. If this does nothing to help, then the fault could reside in the motherboard or hard drive. You can look at this post where I helped out a user with spare parts http://www.fixya.com/support/t1195654-drc8030n_motherboard
Posted on Nov 16, 2008
I had this same problem. All you have to do is unplug the it for a couple of minutes the plug it back up.
Posted on Jan 09, 2009
How do I know if oys a fuse blown
I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.
- Leave your remote away as you won't need it
- Turn off the the unit to STANDBY mode
- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.
- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL
- Press STRAIGHT button until it shows INIT **** ALL
- Press Power to turn off the machine.
- Leave it for 2 sec. then turn on the machine again.
Now your unit turns to factory default setting.
Sep 22, 2013 | Panasonic SA-HE70 Receiver
Pressing stop for more than 5 sec doesn't change 'progressive scan mode'
Please press and hold STOP button for more then 5 seconds to cancel Progressive Scan mode.
Oct 22, 2008 | Philips MDV560VR DVD Player/VCR
How to set time of day clock on 2007 1200n
Turn the key to ACC,
press the button on back of speedo several times until time is displayed,
press and hold for 5 sec, 12HR begins to blink,
press and release to switch between time formats,
press and hold for 5 sec, hours will blink,
press and release repeatedly to set hrs,
press and hold for 5 sec to get blinking minutes,
set minutes similar way,
press and hold for 5 sec to save, when minutes stop blinking the time is set,
turn the key to off.
Jul 27, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Maytag Stove Error Message 5 A6
ok Alvin. help has arived .. turn off the power for a few min ( at the breaker box) turn back on see if clock will set . if not you may have a damaged membrain . now 5 A6 MAY BE A FAULT CODE.. in the control panel is a tec sheet with the codes . hope this will help .. mm
Dec 04, 2009 | Maytag Performa PAV2200
MY 6310 just stopped on me. I have to unplug and plug it back in but stops again. All lights are blinking and it said to RESET POWER.
HP 6310 Reset
There are 3 types of resets in the printer
1.Partial Reset
2.Semi full Reset
3.Full Reset
To do partial Reset.
1. Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3. While holding the button, connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
4.Then turn ON the unit.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 29, 2009 | HP Officejet 6310 All-In-One InkJet...
The Miehle built in coffee maker - I want to stop the cleaning process but it won't clear
1. turn unit off 2. open door, turn power off for 5 secs. ( switch upper left corner )  3. turn power back on, close door. 4. press and hold clear, press on/off. release both simultaneously. 5. immediately , press clear 5 times holding it down the fifth press until the display changes. 6. with menu available, press more until option to reset cleaning appears, select reset cleaning. 7. finished
Nov 02, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
LG Model LHT754 stuck in demo mode
hold the stop button on the receiver not the remote! for twenty seconds
May 24, 2008 | LG LHT734 System
Refilling of canon ink fine cartridge pg 41
Phew! Finally. This one works for my Canon MP140.
Follow all instructions completely or it won't work....
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Apr 26, 2008 | Office Equipment & Supplies
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
RCA DRC8030N Logo
269 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
